knock sensor lacation on my wiring harness????????
Old Oct 7, 2005 | 02:27 PM
WOODman's Avatar
Default knock sensor lacation on my wiring harness????????
IVE GOT A 1995 CIVIC HATCHBACK SI WITH A B16A SWAP...does this model year civic include a knock sensor plug?, because i notice there is a plug on the motor for a knock sensor but i have no wire to plug into it from the stock hatchback wirirng harness...does this affect the car overall or do i need to wire one into the ECU? thanks
Old Oct 7, 2005 | 07:09 PM
hatchi's Avatar
Default Re: knock sensor lacation on my wiring harness???????? (WOODman)
what ecu are you running?? if you have a chipped p28 chances are you dont need the knock sensor. if you are running stock ecu then you will need to wire it up. its on d3 on your ecu
beginmyhonda
Jul 29, 2009 02:14 PM
eskerley
Dec 4, 2007 08:18 PM
crxb16ftw
May 23, 2007 09:32 PM
phanatic
May 18, 2007 02:21 PM
EGTHU6
Jul 28, 2004 01:50 AM
