CTR pistons with ITR valves in LS/vtec...?
Old Mar 4, 2002 | 12:55 PM
HybridCoupe's Avatar
Default CTR pistons with ITR valves in LS/vtec...?
Is there enough piston clearance in ls/vtec with CTR pistons for ITR valves? Is it safe to run ITR valves in this setup?
Old Mar 4, 2002 | 01:09 PM
VTEC4GS's Avatar
Default Re: CTR pistons with ITR valves in LS/vtec...? (HybridCoupe)
valve diameter is no different, valve reliefs on pistons are deep enough. so YES.
Greg
Old Mar 4, 2002 | 06:39 PM
Default Re: CTR pistons with ITR valves in LS/vtec...? (vtec4gs)
thanks alot
Old Mar 4, 2002 | 09:52 PM
ekekek's Avatar
what head are you using?
Old Mar 5, 2002 | 03:17 PM
Default Re: CTR pistons with ITR valves in LS/vtec...? (ekekek)
00 civic si head...
Old Mar 8, 2002 | 09:28 AM
ysrhatch's Avatar
New User
lucky u. thats some mad hp yo.
Old Mar 8, 2002 | 04:19 PM
Kataku2K3's Avatar
Default Re: CTR pistons with ITR valves in LS/vtec...? (hatch_react)
It will work easily, just don't mill the head too much!!!!!
[Modified by JDMspecEG6, 1:19 AM 3/9/2002]
Old Mar 8, 2002 | 09:16 PM
HotRodTeg's Avatar
Default Re: CTR pistons with ITR valves in LS/vtec...? (JDMspecEG6)
Simply Just make sure to run 92 octane and check for pinging cause with the B16 head you should be running around 12:2 comp with Gsr around 12:5 with no milling and stock Ls head gasket
EGtypeR408
Oct 12, 2010 01:12 AM
bOOsT-FeIn
Oct 30, 2006 07:55 PM
JDubya
Feb 21, 2003 09:56 AM
eddiecut
Apr 28, 2002 07:06 PM
HybridCoupe
Feb 11, 2002 08:36 AM
