Gsr vtec crossover points
Old Oct 7, 2005 | 09:59 AM
shyboi4u's Avatar
Default Gsr vtec crossover points
from my understanding, vtec on a gsr hits a 4400 rpm and iab open up at 5800 rpm. then i heard the opposite, iabs open up at 4400 and vtec hits at 5800. can someone please clear this up?
Old Oct 7, 2005 | 10:07 AM
veilsides2000's Avatar
Default Re: Gsr vtec crossover points (shyboi4u)
vtec engages at 4400rpm and the iab i think open at 5795rpm i think im not sure but its not a completely even number in the hundreds. The reason you friend or whoever thinks that vtec hits later is because you don't feel any pull untill the iab's open. That mad Vtec yo
Old Oct 7, 2005 | 10:12 AM
shyboi4u's Avatar
Default Re: Gsr vtec crossover points (veilsides2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilsides2000 &raquo;</TD></TR><TR><TD CLASS="quote">vtec engages at 4400rpm and the iab i think open at 5795rpm i think im not sure but its not a completely even number in the hundreds. The reason you friend or whoever thinks that vtec hits later is because you don't feel any pull untill the iab's open. That mad Vtec yo </TD></TR></TABLE>
thats what i thought. yeah there is no complete number. i was just rounding off the numbers. also i bought a chipped ecu and i don't feel vtec kicking in around the setting that its suppost to be like arond 45 i believe. i do feel something around 58 tho. so i'm thinking that i have a sohc vtec ecu. i don't throw any codes tho.
Old Oct 7, 2005 | 10:39 AM
hobo_ken's Avatar
The pull is more noticeable when the iab opens up. You don't really feel the pull when vtec kicks in.
Old Oct 7, 2005 | 10:59 AM
1bad-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboi4u &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i thought. yeah there is no complete number. i was just rounding off the numbers. also i bought a chipped ecu and i don't feel vtec kicking in around the setting that its suppost to be like arond 45 i believe. i do feel something around 58 tho. so i'm thinking that i have a sohc vtec ecu. i don't throw any codes tho.</TD></TR></TABLE>What's the serial number on the ecu? You can tell what type of ecu you have by looking at the serial number.
Old Oct 7, 2005 | 11:51 AM
2G0S0R1's Avatar
New User
Default Re: Gsr vtec crossover points (1bad-eg)
4400 vtec, 5750 iab (according to helms)....
with R cams, it feels good at 5000 vtec, 5600 iab.
idle... brrrrrrr.... pop.... breeeeee.... click.... BWAAAHHHHHHHH.... 8500rpms... Slam... squee.e.e.l... -&gt;
Old Oct 7, 2005 | 12:48 PM
shyboi4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad-eg &raquo;</TD></TR><TR><TD CLASS="quote">What's the serial number on the ecu? You can tell what type of ecu you have by looking at the serial number.</TD></TR></TABLE>
right now i have the stock p72 obd 1. on the chipped ecu there is not serial number because they take it off when they chipped it. i tried to figure out what ecu it was.
Old Oct 7, 2005 | 04:21 PM
batmang yO!
Guest
Posts: n/a
while crusing in 2nd gear, slowly accelerate to 4400rpms and you will feel/hear vtec, its subtle, but its there at 4400.
Old Oct 7, 2005 | 04:43 PM
integra686's Avatar
Default Re: Gsr vtec crossover points (Beavis)
you thinc on a bolt on gsr its any good to lower the iabs or vtec points?
Old Oct 7, 2005 | 07:20 PM
shyboi4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beavis &raquo;</TD></TR><TR><TD CLASS="quote">while crusing in 2nd gear, slowly accelerate to 4400rpms and you will feel/hear vtec, its subtle, but its there at 4400. </TD></TR></TABLE>
thats funnie because i do be doing that. it does exactly what you said.
Old Oct 7, 2005 | 07:22 PM
shyboi4u's Avatar
Default Re: Gsr vtec crossover points (integra686)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra686 &raquo;</TD></TR><TR><TD CLASS="quote">you thinc on a bolt on gsr its any good to lower the iabs or vtec points?</TD></TR></TABLE>
you can't lower vtec with a bolt. what bolt are you talking bout?
Old Oct 7, 2005 | 07:26 PM
projectTeG's Avatar
Default Re: Gsr vtec crossover points (2G0S0R1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2G0S0R1 &raquo;</TD></TR><TR><TD CLASS="quote">4400 vtec, 5750 iab (according to helms)....
lol, thats the same in my ls but with out the 8200rpm redline and vtec, but mines more like
idle.....ruuuuuuuuuuuuuuuuuurrrrrrrrrggggggggggg,, ,,,,,,,,,braaaaaaaaaaaaaaaghhhhhh.....7200rpms.... ...slam squiriiiiiirrrrrrrrt!!!!!!......braaaaaaaaghhhghgh g,,,,,7200rpms....slam!.....squeeeel!.......braaaa aaaaaaaaaaaaaaaaaaghhhh......7000rpm.....slam ..chirp!
Old Oct 7, 2005 | 09:00 PM
shyboi4u's Avatar
Default Re: Gsr vtec crossover points (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">lol, thats the same in my ls but with out the 8200rpm redline and vtec, but mines more like
idle.....ruuuuuuuuuuuuuuuuuurrrrrrrrrggggggggggg,, ,,,,,,,,,braaaaaaaaaaaaaaaghhhhhh.....7200rpms.... ...slam squiriiiiiirrrrrrrrt!!!!!!......braaaaaaaaghhhghgh g,,,,,7200rpms....slam!.....squeeeel!.......braaaa aaaaaaaaaaaaaaaaaaghhhh......7000rpm.....slam ..chirp! </TD></TR></TABLE>
dang you chirp in 3rd gear?
Old Oct 7, 2005 | 09:08 PM
projectTeG's Avatar
yea and sumtimes in 4th, lol, i was shocked....i got bored ine night and spun tires for alil bit from 3rd from a dead stop (couldnt hold it for long), and i can chirp going from first to third. i thought it was a fluke at first until i went to my local 1/8th mile track and chirped 3rd. its that MaD NoN-VtaK P0w3R Y@!!!
Old Oct 7, 2005 | 09:12 PM
b20acura's Avatar
Default Re: (projectTeG)
sorry about the newbie question. but what is iab.
Old Oct 7, 2005 | 09:24 PM
projectTeG's Avatar
Default Re: (b20acura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura &raquo;</TD></TR><TR><TD CLASS="quote">sorry about the newbie question. but what is iab.</TD></TR></TABLE>
im not sure abour the technical term. but its the secondary butterfly system thats on the b18c1, h-series engines, and most f-series as well/
Old Oct 7, 2005 | 09:55 PM
shyboi4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">yea and sumtimes in 4th, lol, i was shocked....i got bored ine night and spun tires for alil bit from 3rd from a dead stop (couldnt hold it for long), and i can chirp going from first to third. i thought it was a fluke at first until i went to my local 1/8th mile track and chirped 3rd. its that MaD NoN-VtaK P0w3R Y@!!! </TD></TR></TABLE>
haha, thats koo. i should try it someday. 1st to 3rd.
Old Oct 7, 2005 | 11:54 PM
shyboi4u's Avatar
Default Re: (shyboi4u)
SimplyTron
13
Oct 13, 2007 02:16 PM
finest_GSR
Apr 6, 2006 09:09 PM
97dc2
Sep 23, 2004 12:00 AM
Master23
Jul 8, 2004 10:25 AM
escape2me
Apr 26, 2004 02:44 PM
