ls motor 155psi compression????
Old Oct 7, 2005 | 08:36 AM
mycrx7's Avatar
Default ls motor 155psi compression????
ok it smokes like a mother, ive tried another head but it was junk when i got it was well maybe thats y they were gave to me? but the comp is 155 is that very bad? it seems low just not low enough to smoke like it does, could the valve guides or something in the head just be all fucked up? o ya the head thats on there **some moron** ported it with the valve train still in it so ya im sure that could have something to do with it.
Old Oct 7, 2005 | 09:19 PM
Steve-o's Avatar
Default Re: ls motor 155psi compression???? (mycrx7)
if it smokes white smoke all the time you might have antifreze leaking in the cylinder!? if it smokes at start up it might be you valve guides..
Old Oct 8, 2005 | 05:41 AM
LShatchie's Avatar
piston rings ?
Old Oct 8, 2005 | 05:53 AM
loudassVTEC's Avatar
Default Re: ls motor 155psi compression???? (LShatchie)
What color smoke?? Blue-ish white, black, or white like steam with a sweet smell to it???
Old Oct 8, 2005 | 07:39 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 &raquo;</TD></TR><TR><TD CLASS="quote">ok it smokes like a mother, ive tried another head but it was junk when i got it was well maybe thats y they were gave to me? but the comp is 155 is that very bad? it seems low just not low enough to smoke like it does, could the valve guides or something in the head just be all fucked up? o ya the head thats on there **some moron** ported it with the valve train still in it so ya im sure that could have something to do with it.</TD></TR></TABLE>
well my LS has 150 compression all across the board. i also tested it with 3 jumps of the needle, instead of 10 complete turns of the starter like most people do. that was over a year ago and my car runs perfectly fine...
Old Oct 8, 2005 | 07:46 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: ls motor 155psi compression???? (benb18a)
Did you have the throttle wide open during the test? 155 across all 4 cylinders as well? When there's a large variance between the cylinders, it's a bad thing. When they're all the same, it's actually okay....well, to a point.
The smoke is bad, however. Answer this question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">What color smoke?? Blue-ish white, black, or white like steam with a sweet smell to it???</TD></TR></TABLE>
Old Oct 8, 2005 | 11:07 AM
mycrx7's Avatar
Default Re: ls motor 155psi compression???? (shamoo)
the test was done with the throttle wide open, also the smokes kind of a blueish white. it puffs smoke right when i start it up and from then after if u rev it, i just picked up a obd1 p75 ls head today, i hope this works out for me.
Old Oct 8, 2005 | 11:08 AM
mycrx7's Avatar
the compression is give or take number or two ,but the numbers were consitant with each other.
Old Oct 8, 2005 | 11:54 AM
.one lane's Avatar
.likes trains
It sounds like you're burning oil
Old Oct 9, 2005 | 06:51 AM
mycrx7's Avatar
Default Re: (Mr. One Lane)
well ya of course im buring oil, now the problem is find out where its coming from? thats my prob.
Old Oct 9, 2005 | 10:35 AM
95lstegman's Avatar
Default Re: (mycrx7)
piston rings = $100, rod + main bearings = $100, ridge reamer, ring groove cleaner, and bore honer from autozone borrowed = $0, new valve seals from Honda/Acura = $50, head gasket = $50 from stealership or autozone even less. there's your price list. $300 takes care of the major causes of oil consumption.
Old Oct 10, 2005 | 07:39 AM
mycrx7's Avatar
Default Re: (95lstegman)
today im putting the head on, if it doesnt work looks that thats what ill have too do.
aser1z
Honda S2000
24
Aug 24, 2008 03:00 PM
welfarepc
Oct 7, 2007 11:10 AM
cecilseahawks
Nov 7, 2003 08:19 PM
petrv
Jul 11, 2003 11:53 AM
Thats-so-Ls
Nov 12, 2001 10:10 AM
