F21A Rear Balance Shaft Question
Old Oct 7, 2005 | 03:50 AM
Icemanxxxv's Avatar
Default F21A Rear Balance Shaft Question
While changing my timing belts on my 1993 Honda Accord EX(JDM Engine) F21a I failed to install the rear balance shaft holding tool through the maintenance hole before removing the belt. Susequently the rear balance shaft rotated.
Can I just line up the rear balance shaft through the maintenance hole with the bolt realign the front balance shaft with it's alignment marks and install the timing belt?
I see what looks like a indentation on the rear shaft pully front and a notch on the pully aft edge they are just short of 180 degrees from each other. Do these marks have to line up some where before I install the aft shaft holding tool?
Thanx!
Old Oct 17, 2005 | 09:48 AM
Icemanxxxv's Avatar
Default Re: F21A Rear Balance Shaft Question (Icemanxxxv)
Did I scew the pooch on this one? I haven't seen an answer et
gort
Feb 5, 2017 02:34 PM
tweaked.crx
Nov 6, 2012 06:55 PM
anahiem714
Aug 11, 2008 04:50 AM
rasta420
Jan 3, 2007 11:09 AM
D15B7
Oct 18, 2002 02:03 PM
