Suspension & Brakes Theory, alignment, spring rates....
HELP PLEASE
Old Oct 6, 2005 | 10:16 PM
TurboedDelSol's Avatar
Default HELP PLEASE
front wheels are cambering inward from bottom what can be the cause. 94 del sol it is lowered dont undestand why it is cambering inward please help
Old Oct 7, 2005 | 04:27 PM
DC2SirG's Avatar
Default Re: HELP PLEASE (TurboedDelSol)
If i understand you right then it makes perfect sense... The more you lower a car the more it affects it camber, your tires are probably wearing on the insides. Sounds like you need a camber kit, it will set it more correct and reduce the wearing down!
Old Oct 7, 2005 | 08:16 PM
PIC Performance's Avatar
Default Re: HELP PLEASE (DC2SirG)
If the bottoms of the tires are pointing inwards, the tops are pointing out, which makes it positive camber. You gain negative camber from lowering a car, not positive. You don't need a camber kit to cut down on abnormal tire wear, because its toe that causes the most wear. An alignment is what would be needed.
To the OP, did you get into an accident with the car? Something might be bent, causing the positive camber. Take a look under the fron suspension, see if there is any damage. Or take it to a shop, get it on an alignment rack and see what you see.
2n-chilli
Suspension & Brakes
Apr 14, 2011 06:24 PM
blkcivic310
11
Mar 11, 2010 03:57 PM
sublimeh215
Suspension & Brakes
Feb 10, 2009 07:34 PM
E36 Guy
16
Apr 7, 2006 09:58 AM
blazin247nc
18
Jan 10, 2005 10:32 AM
