clutch master cyl.
Old Oct 6, 2005 | 09:47 PM
95DxSi-R2
Guest
Posts: n/a
Default clutch master cyl.
i have a 95 dx with b16, gsr trans. i bought a Slave and master cylinder from Honda, and still no clutch. do i need an integra, del sol, or si master cylinder? Like it's not creating enough psi to disengage the clutch?
Old Oct 7, 2005 | 06:34 AM
95DxSi-R2
Guest
Posts: n/a
Default Re: clutch master cyl. (95DxSi-R2)
bump
Old Oct 7, 2005 | 06:44 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote"> do i need an integra, del sol, or si master cylinder? </TD></TR></TABLE>
yes
If it's not working right, check the floor under your pedals for fluid leaking down under the carpet.
Old Oct 7, 2005 | 04:25 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: clutch master cyl. (IHateJDM)
no leaks, gonna have my buddy come over to help me bleed it again
Old Oct 7, 2005 | 04:30 PM
litterbox's Avatar
I am a (Trial User) Army
Integra/Civics are the same 5/8'' I looked into this.
Adjust the rod that connects your pedal to your clutch MC. Turn it away from the firewall.
Old Oct 7, 2005 | 04:35 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: clutch master cyl. (litterbox)
did it
Old Oct 7, 2005 | 04:37 PM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">did it</TD></TR></TABLE>Like all the ******* way? Adjust it to the MAXX!
Old Oct 7, 2005 | 04:38 PM
mestizo's Avatar
open up all the connections on the hydro line from the clutch master cylinder to the slave cylinder and bleed it at each one, sounds strange i know but it worked for me when i had no clutch after a swap, i guess a bubble or some sort of blockage stopped it from working but after doing this it worked fine and hasn't had a problem since.
Old Oct 7, 2005 | 04:42 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: clutch master cyl. (mestizo)
thats what my buddy said, he said honda clucth'c can be a bitch somethimes to bleed. I thought if i let it gravity bleed, and then bleed it manually that it would be alright, so he's gonna come over and help.
707EF8
Jul 29, 2006 08:32 PM
hip_hop_s0ulchild
Oct 22, 2005 01:35 PM
hybridgs
Aug 26, 2005 06:39 AM
TurblowR
Mar 28, 2005 06:26 PM
