H23 Stuff W/ H22 Stuff??
Old Oct 6, 2005 | 07:41 PM
95accordh22a's Avatar
Default H23 Stuff W/ H22 Stuff??
alright well a buddy of mine asked me a question today and i didnt know the exactly answer so I will ask you guys.
He has an H22 block with an H23 Crank and H23 Rods with Type s OS pistons
he told me that the pistons sit over the top of the block a little bit (havent seen it myself) and he is worried about valve clearance? can anyone help him out?
Old Oct 7, 2005 | 05:14 AM
xxredpreludesixx's Avatar
Default Re: H23 Stuff W/ H22 Stuff?? (95accordh22a)
Someone correct me if im wrong but... The h23 has a longer stroke hence the piston will go down further and come up further and since instead using h23 pistons he used slighty taller h22 type-s pistons they will sit out a little bit not much. As far as valve clearences i dont see any problem they dont stick out far enough but again someone correct me if im wrong.
Old Oct 7, 2005 | 05:33 AM
Honda318dx's Avatar
Default Re: H23 Stuff W/ H22 Stuff?? (xxredpreludesixx)
I'm pretty sure just the dome sticks out of the block..
Old Oct 7, 2005 | 05:41 AM
Default Re: H23 Stuff W/ H22 Stuff?? (Honda318dx)
yea thats what i meant someone on another honda site had a picutre of it i cant remember which site if i find it ill post up some pics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure just the dome sticks out of the block..</TD></TR></TABLE>
do you agree though he shouldnt have any clearence problems with his valves should he??
Old Oct 7, 2005 | 10:19 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxredpreludesixx &raquo;</TD></TR><TR><TD CLASS="quote">yea thats what i meant someone on another honda site had a picutre of it i cant remember which site if i find it ill post up some pics.
do you agree though he shouldnt have any clearence problems with his valves should he??</TD></TR></TABLE>
he wont have any clearances with stock cams...with stage 2's or 3's there might be some issues.....
Old Oct 8, 2005 | 06:20 AM
Default Re: H23 Stuff W/ H22 Stuff?? (SB tuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning &raquo;</TD></TR><TR><TD CLASS="quote">
he wont have any clearances with stock cams...with stage 2's or 3's there might be some issues.....</TD></TR></TABLE>
yea that sounds right he 95aord what stage cams are u running??
Old Oct 8, 2005 | 09:04 AM
this is a friend of mines motor and i think he is running stage 1 cams
Old Oct 8, 2005 | 10:01 AM
ok then yea. he should be fine and shouldnt have any issues.
Old Oct 8, 2005 | 10:03 AM
mgags7's Avatar
^^ he knows this because he has measured your friends cams, knows that he had appropriately stiff valve springs....and knows that he hasnt milled the head excessively....
you can see how we like this guy a lot around here....hes full of great info....
Old Oct 9, 2005 | 12:10 PM
accord387's Avatar
clay the motor, otherwise its all just guesswork with what kind've clearances you will have.
HksHaitian
Sep 15, 2013 01:09 PM
boostedh22lude1
Nov 1, 2007 10:53 PM
boostedh22lude1
Oct 16, 2007 01:22 PM
Jdmprelude94
Apr 16, 2005 09:10 AM
Smurfylude
Jun 2, 2002 04:06 PM
