GM 3 Bar with S-AFC
Old Oct 6, 2005 | 06:48 PM
onemoreday21's Avatar
Default GM 3 Bar with S-AFC
Ok, i need to know if I can hook a gm 3 bar up wire for wire on my 94 turbo LS. I know its not the smartest idea with an s-afc but ive had 3 other turboed hondas with an afc and never any problems. Im not looking to run insane boost just around 12 or 13 and i know the stock MAP runs outta room at a little over 10. I already tried team-integra.net and i couldnt get anybody to say anything except that its stupid with an afc. Ill worry about the reliability issues. I just need to know if it can be done or if there is some setting that I hafta change on the afc for it to be done. I would really like some help here so anything kinda answer will do.
Old Oct 6, 2005 | 06:56 PM
boosted k20's Avatar
Default Re: GM 3 Bar with S-AFC (onemoreday21)
ur stock ecu would probably go crazy with the 3bar. u need to have a chipped ecu scaled for a 3-bar. and u r brave run n over 8 psi on a SAFC
Old Oct 6, 2005 | 07:36 PM
Deluzional's Avatar
Default Re: GM 3 Bar with S-AFC (boosted k20)
i ran the afc with a t25 perfectly fine...but when i upgraded to a sc34...i cracked cylinder 2/3, and this wasnt even 10psi or WOT...go with something else
voodoo on 23s
May 18, 2009 07:12 PM
MrRide2Low
Jun 1, 2007 09:04 AM
FMIDRC Racer
Aug 31, 2006 03:09 PM
Ntense90crxsi
Mar 26, 2006 08:24 AM
BorderM3
Mar 31, 2003 07:03 AM
