How do you check ODB2 codes without a scaner???
I have a OBD2 car. I read a post before that you can jump two points on the OBD2 scan tool conection. Seeing that there is about 12 pins what two do you conect them to?? I know one it a ground and the other is for the ECU to recive the codes so it blinks on the dash.
I know that the codes for OBD2 are P**** but Im just looking for a close idea to wahts going on. Thanks
there should be a green 2 prong plug under the kick panel were the ecu is located.
take a piece of wire and put into the plug. the ecu should start blinking your codes go from there
blowme
Jun 29, 2005 04:58 PM
Bimmerman
May 25, 2005 02:16 PM
topher
Feb 2, 2002 10:46 AM
