Engine getting no spark.
Old Oct 6, 2005 | 09:00 AM
import_king20's Avatar
Default Engine getting no spark.
The distributor went out on my 98 gsr so i replaced it to find out that its still getting no spark. It turns over now but like i said...no spark...what could it be?
Old Oct 6, 2005 | 09:16 AM
Old_Honda's Avatar
Default Re: Engine getting no spark. (import_king20)
When you replaced the distributor, did you get a complete new one, or did you use your old coil and igniter?
Old Oct 6, 2005 | 12:45 PM
94gsr18kid's Avatar
Default Re: Engine getting no spark. (OldGSR)
Spark comes from the secondary windings in your ignition coil that goes to your secondary wire, to the distributor, out the wires to your spark plugs. Make sure your ignition coil is working properly. I would say thats your problem. Tell us how it turns out.
BTW Are you sure your distributor was the problem? When you re-installed it was it timed correctly?
Old Oct 6, 2005 | 02:01 PM
98 Spec R's Avatar
Use a volt meter to make sure you have power at the ignitor wire at the distributor engine harness plug. If you have power there its either the ignitor or coil in the distributor.
Old Oct 6, 2005 | 02:45 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
do whole new dizzy's come with dizzy caps?.. if not, that could be your problem
Old Oct 7, 2005 | 02:01 AM
i got the whole dizzy brand new whent to a diff store to the the cap!
EsCo_EsCo
Sep 29, 2008 08:25 AM
crxion91
Jan 19, 2008 12:35 PM
88 honda prelude
Jul 28, 2007 05:50 AM
KaRiZMa
Nov 7, 2004 03:30 AM
FitCRX
Feb 3, 2003 07:13 PM
