H22 will not pull or turn up past 6k!!!!
Old Oct 6, 2005 | 08:52 AM
j spec's Avatar
Default H22 will not pull or turn up past 6k!!!!
wondering if the coil could have something to do with it its a brand new blaster ss or maybe the ignition control module?
Old Oct 6, 2005 | 11:05 AM
staticrex's Avatar
Default Re: H22 will not pull or turn up past 6k!!!! (roma's h22eg6)
do you have any cel's?
Old Oct 6, 2005 | 12:46 PM
darkfx's Avatar
check your oil level
Old Oct 9, 2005 | 11:34 AM
j spec's Avatar
Default Re: (darkfx)
no cel, checked the compression, timeing, no obstruction in exhaust, tried different ecu, bought new high impedence 370 rc injectors, new walbro 255 fuel pump, can't think of anything else thanks
Old Oct 9, 2005 | 12:36 PM
optikal_blitz's Avatar
have you tried going back to your stock ignition setup?
Old Oct 9, 2005 | 03:07 PM
veganej's Avatar
Default Re: (optikal_blitz)
what setup are you running and in what chassis. i had the same problem, make sure if you had low impedence injectors and switched to high that you do NOT still have the resisitor box wired. and make sure the injectors are your correct application. i may be out in the left field with that advice but it may be the problem, i had a similar problem.
Old Oct 9, 2005 | 04:25 PM
PrettyLude's Avatar
switch it to the stock coil and see if it goes away
thatguyjade
Jun 28, 2018 11:11 AM
SL0WEGG
Jan 4, 2006 10:17 AM
Sunsport
Oct 27, 2005 01:18 PM
j spec
Oct 11, 2005 05:02 PM
dand39
Feb 19, 2005 07:41 PM
