Cam gear ?'s
After some in depth reading on here I still have not found what I am looking for. So my question is what cam gears are a good brand to buy? I have been looking so far at Buddy Club and Skunk 2. My future goal is to have 200WHP if that has any bearing on your comments. I do not want to spend a fortune ie: Spoon, Toda, ect. Thanks in advance.
cam gears without cam shafts is purely cosmetics. Sure you can tune it the sprockets with stock camshaft and get a few ponies but I suggest getting some itr or ctr camshafts for higher lift, aftermarket sprockets and possibly hondata and you'll gain some power. If your looking to reach 200 whp, I suggest getting aggrasive aftermarket cams, dual valve springs, retainers, and all necessary bolt-ons. May even need to get higher compression piston.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK »</TD></TR><TR><TD CLASS="quote">cam gears without cam shafts is purely cosmetics. Sure you can tune it the sprockets with stock camshaft and get a few ponies but I suggest getting some itr or ctr camshafts for higher lift, aftermarket sprockets and possibly hondata and you'll gain some power. If your looking to reach 200 whp, I suggest getting aggrasive aftermarket cams, dual valve springs, retainers, and all necessary bolt-ons. May even need to get higher compression piston. </TD></TR></TABLE>
Yeah agreed, and if you're looking to achieve 200whp cam gears should be the last of your worries right now
DO NOT GET THE BUDDY CLUB"S! those things are not accurate, trust me! my friend had them in his itr. big mistake and appearantly, he's not the only one with the problem. buddy club camgears =
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky_captain »</TD></TR><TR><TD CLASS="quote">DO NOT GET THE BUDDY CLUB"S! those things are not accurate, trust me! my friend had them in his itr. big mistake and appearantly, he's not the only one with the problem. buddy club camgears =
just curious why those cams are big mistake? what is the downside those those cams? I bought some bc spec IV on my itr and works wonder.....
</TD></TR></TABLE>just curious why those cams are big mistake? what is the downside those those cams? I bought some bc spec IV on my itr and works wonder.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkDragon »</TD></TR><TR><TD CLASS="quote">iv seen the design of these gears and they dont seem to have timign marks on them and only adjustable to a limited extent</TD></TR></TABLE>
hey, we have almost the same avatar only i edited mine. darn, i was liking this one. time to change it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue »</TD></TR><TR><TD CLASS="quote">it takes alot to get a honda to 200whp NA</TD></TR></TABLE>
what, is the NSX not a honda? i bet you the newer Odyssey minivans even make 200whp easily
I am going to be heading towards 200whp. As of right now i am just trying to put down close to 175whp. If I could get close to that I would be happy for now. Yes my plans are to try to get to 200whp someday, money is my only limiting factor right now. I just spent quite a bit on the "basics". Yes I will eventually get cams and all of that but for now I'm working with intake, header, hi-flo cat, exhaust, FPR, and V-AFCII. I have been reading some articles and posts on Team-Integra (my second home) and there have been some pretty good gains just from i/h/c/e and V-AFC. So I figured if I'm gonna dyno and tune I might as well try to get as much as I can without spending too much more money and cam gears are what came to mind. So thats where I'm at right now.
not a bad choice. if you can push for the civic type r cams, do it! there is a big gain over gsr cams, and no aftermarket springs required. but thats not a bad choice overall. dont be negativley influenced, good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">He said cam GEARS, not cams.</TD></TR></TABLE>
I got the whole bc package....nothing wrong with the gears....
be sure to measure and compare to the oem one's. they may be ok, but there is no reason to have to go through the trouble. one of my friend's gears was definently not acurate, plus they are tough to read. they are not first (or 5th) choice in that category of mine. but like i said, just check em, they might be ok. but beware!
Gabe_
Dec 23, 2003 07:24 AM
