To those with EG6 CLUSTER *HELP*
Old Mar 4, 2002 | 08:30 AM
Kool305's Avatar
Default To those with EG6 CLUSTER *HELP*
the emergency break light NEAR THE GAS GAUGE keeps on coming on and off at times when i'm driving. WHAT DOES IT MEAN????? you all know what i'm talking about right, it looks like this ( 0 ) in red. PLEASE LET ME KNOW.
By the way I got my cluster from Hondamotorsonline.com great people SUPER CLEAN, FAST SHIPPING and,GREAT BUSINESS.
Old Mar 4, 2002 | 08:46 AM
Black_eh2's Avatar
New User
Default Re: To those with EG6 CLUSTER *HELP* (Kool305)
maybe your brake is unstable?
[Modified by SleeperEG6, 5:46 PM 3/4/2002]
Old Mar 4, 2002 | 09:13 AM
eg6ajk's Avatar
maybe its your switch or loose connector somwhere (possibly on the m/c)
M/C connection as well as the level of fluid can set it off so if its low or the two connectors are not plugged in all the way you will get this problem
Old Mar 4, 2002 | 10:23 AM
ahcjar103's Avatar
Default Re: To those with EG6 CLUSTER *HELP* (eg6ajk)
i have no problems with mine. check wiring and adjust the cable if it hasn't been adjusted in a while.
Old Mar 4, 2002 | 07:10 PM
TurboBumblBee's Avatar
this same thing happened to me once and it ended up being that i dropped a socket in there and it was grounding out the switch making the brake light come on.. check that out, if not check the master cylinder to make sure there is fluid and maybe adjust handbrake cable..
Old Mar 4, 2002 | 07:20 PM
DualKnuttz's Avatar
Banned
Check your brake fluid. It might be low and that causes the light to go off.
Old Mar 4, 2002 | 07:54 PM
Kool305's Avatar
Default Re: To those with EG6 CLUSTER *HELP* (DualKnuttz)
I found the problem it was my brake fluid too low THANKS GUYS.
oscarlx
Jul 1, 2012 08:54 PM
blinx9900
Dec 14, 2006 08:42 AM
HatchedGTI
Jan 23, 2006 08:45 PM
TheBobFather
Nov 12, 2005 09:37 AM
hmongdude
Jul 10, 2003 10:19 AM
