CTR Pistons
Old Oct 5, 2005 | 03:55 PM
Dirtfall's Avatar
Default CTR Pistons
I found a good deal on some ctr pistons. In the add it said "I polished the tops of these pistons on a buffer wheel at work. I just got rid of the sharp edges." That worried me so i emailed him about it and ask him how much metal he removed and this was his response. "Here is a picture if you are worried about that. Yes I removed metal but very very little. Probably less than a gram total. I removed the lettering on the compression flat, I removed the little piramyd between the valve releifs, I removed the arrow that points forward and I removed the center mark. Basically I just smoothed out any possible rough edges. I work in a machine shop So I polished these up on my lunch hour one day. I did basically the same thing to another set of these. When I tore that motor apart I could take the carbon on the top and wipe it off with my finger because the piston was smooth. Does it help maybee not but I felt better doing it." I posted the picture he gave me below. Do you guys think these will be alright? Since he polished off all the numbers to you think these could be impostures? Would that affect my compression at all? Thanks
Old Oct 5, 2005 | 04:07 PM
HondaIntegraR's Avatar
Default Re: CTR Pistons (Dirtfall)
something to think about is that if the pistons are shaved off differently, it will effect compression in that not all cylinders will yield the same compression
Old Oct 5, 2005 | 04:25 PM
EKhatch's Avatar
Picture isn't showing up for me.
Old Oct 5, 2005 | 04:34 PM
EF'n Sedan's Avatar
Default Re: CTR Pistons (EKhatch)
i think he meant that he Deburred the pistons!
Old Oct 5, 2005 | 04:56 PM
unknown0001's Avatar
Default Re: CTR Pistons (NAtural_asPIRATIONs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAtural_asPIRATIONs &raquo;</TD></TR><TR><TD CLASS="quote">i think he meant that he Deburred the pistons!</TD></TR></TABLE>
please explain...
I'd think doing so would be not very good for the piston itself?
Old Oct 5, 2005 | 05:14 PM
EKhatch's Avatar
Default Re: CTR Pistons (Mr.RHTuner)
Smoothing off any sharp edges is fine, actually recomended by most. I would be a bit leary buying the pistons but all we have to go by is one picture.
Old Oct 5, 2005 | 06:57 PM
Dirtfall's Avatar
Alright thanks guys. Its better to be safe then sorry. I guess i will just buy the pistons from HMotors.
Old Oct 5, 2005 | 07:27 PM
KingHornet's Avatar
My pistons came with a valve
Old Oct 5, 2005 | 09:49 PM
Dirtfall's Avatar
Default Re: CTR Pistons (ChampWht)
**** that had to suck
Old Oct 5, 2005 | 10:17 PM
EF'n Sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">
please explain...
I'd think doing so would be not very good for the piston itself?</TD></TR></TABLE>
when u smooth out the sharp edges on the top of the piston to reduce the chances of having hot spots!
Old Oct 5, 2005 | 11:27 PM
jisu009's Avatar
looks fine to me.
It is actually a good thing to do...it reduces little ridges and imperfections that cause "hot spots" which lead to pre ignition.
Old Oct 6, 2005 | 03:09 AM
Cherchez La Ghost's Avatar
that wasn't nessessary. name one person who has had "hot spots" on an OEM honda piston?
Old Oct 6, 2005 | 05:11 AM
SecretAgent's Avatar
Default Re: (Lekz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lekz &raquo;</TD></TR><TR><TD CLASS="quote">that wasn't nessessary. name one person who has had "hot spots" on an OEM honda piston?</TD></TR></TABLE>
you don't go to the forced induction forum too often do you??
Old Oct 6, 2005 | 06:54 AM
Default Re: (SecretAgent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SecretAgent &raquo;</TD></TR><TR><TD CLASS="quote">
you don't go to the forced induction forum too often do you?? </TD></TR></TABLE>
edit : ...On an All motor engine...
sorry if i wasnt clear but i was referring to an all motor engine since i did post this in an all motor subforum
Unphzd
Oct 6, 2011 12:07 AM
itr1244
Jun 7, 2006 10:55 AM
dc2gsr96
24
Feb 20, 2006 12:34 PM
RenzoDaPlayboi
Nov 22, 2005 08:33 AM
