clutch fluid looks like dirty oil in only a week? sup with that?
Old Oct 5, 2005 | 03:12 PM
verbol assassin's Avatar
Default clutch fluid looks like dirty oil in only a week? sup with that?
k. so i flush out my system, and then a week later, i take a look, and i see its nothng but black slush.
anyone know why?
just did a tranny swap so everything is new including a resurafaced flywheel.
xtd stage 1 clutch.
got a 96 teg ls.
Old Oct 5, 2005 | 03:15 PM
SilverDc2's Avatar
Default Re: clutch fluid looks like dirty oil in only a week? sup with that? (verbol assassin)
is that your original tranny?, try warming up your engine/tranny maybe will loosen up all the slush and do it again until it comes out clean.
Old Oct 5, 2005 | 03:19 PM
Default Re: clutch fluid looks like dirty oil in only a week? sup with that? (SilverDc2)
no, i did an auto to manual conversion. the transmission was dirty with i got it.
Old Oct 5, 2005 | 03:21 PM
SilverDc2's Avatar
same thing happen to me, i did a 5speed conversion i did a tranny flush two weeks later it was black
so what someone told me is to warm up the engine/tranny to mix the slush with the oil...keep changing it til it comes out clean, shouldn't take more than 2-3 times.. while your at it, get a magnetic bolt... clean up all the shavings
Old Oct 5, 2005 | 03:37 PM
cool, good to see im not the only one with this issue.
also, sometimes, i have problems shifting to 1st.
Old Oct 5, 2005 | 05:23 PM
SilverDc2's Avatar
i did too, still do uphill mainly, the linkage rubs on the frame i need to cut it a little more just a few MM
Old Oct 5, 2005 | 06:16 PM
Sack Master's Avatar
Default Re: clutch fluid looks like dirty oil in only a week? sup with that? (cnaman)
You said clutch fluid. Everyone is answering tranny fluid. So which one is it? The brake fluid from the master to the slave cylinder or the actual oil inside the transmission?
Old Oct 5, 2005 | 06:29 PM
It probably had gunk in it unless it was all brand new stuff. It should be pretty clean after only a week of use. But it will start to turn black after a while. Mostly because it burns and gets little pieces of rubber in it from the lines and cylinders. There is nothing you can do about it. But if you are worried then I would flush it a couple times so its all clean.
Old Oct 5, 2005 | 07:22 PM
SilverDc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnaman &raquo;</TD></TR><TR><TD CLASS="quote">cut what?</TD></TR></TABLE>
when you do a 5speed conversion you need to cut a little but where the shift linkage goes.... rubs on the cars frame.. a little... i guess i didn't trim it good enough.
Old Oct 5, 2005 | 08:00 PM
PnoyJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verbol assassin &raquo;</TD></TR><TR><TD CLASS="quote">k. so i flush out my system, and then a week later, i take a look, and i see its nothng but black slush.
anyone know why?
xtd stage 1 clutch.
got a 96 teg ls.
why the heck were u banned so many times
ReyIntegra
Jun 24, 2007 12:18 PM
EK-NICE
Oct 6, 2005 08:41 AM
ceLtic
Apr 8, 2004 08:33 PM
Replica_Racer
Jun 21, 2002 02:26 PM
Replica_Racer
Jun 20, 2002 09:42 PM
