Suspension & Brakes Theory, alignment, spring rates....
Inherited some coilover sleeves, but rubber rings are missing....suggestions?
Old Oct 5, 2005 | 02:52 PM
EL-Driver's Avatar
Default Inherited some coilover sleeves, but rubber rings are missing....suggestions?
Okay I juss inherited some coilover sleeves from a friend of mine who juss had his civic re-ended by the local public transit bus....
anyways.....so he gave me his coilover sleeves.....which I plan to put onto my daily driver.....
the only downside is that I have no rubber rings that secure the sleeve to the shock?
can anyone recommend what would be a solid way to secrure these things...
thanks for your help
Old Oct 5, 2005 | 05:25 PM
JesseCRX's Avatar
Default Re: Inherited some coilover sleeves, but rubber rings are missing....suggestions? (EL-Driver)
It may be ghetto but it works....use strong tape. Like Electrical tape or duct tape. Go around the shock a few times and make sure the sleeve sits nice and snug. Don't force it down cuz then the sleeves will be a bitch to take off later on. Just make sure the tape is on there nice and tight with no sloppy ends. It worked like a charm for me.
Old Oct 5, 2005 | 06:32 PM
gsrious's Avatar
Default Re: Inherited some coilover sleeves, but rubber rings are missing....suggestions? (JesseCRX)
that will work.... or you can just go to the hardware store and buy a whole bunch of o-rings to make it fit snugly.
ep3man
Jun 1, 2008 01:05 PM
civic4dizoor
Suspension & Brakes
May 11, 2007 08:02 AM
ej8luver
Suspension & Brakes
Mar 3, 2006 08:21 PM
Chuji
Sep 11, 2003 09:00 PM
BlueSi2k
Jul 16, 2002 09:51 AM
