starting my ls/vtec build...replace or use the stock bearings?
Old Oct 5, 2005 | 02:41 PM
unknown0001's Avatar
Default starting my ls/vtec build...replace or use the stock bearings?
Hey guys, after months of searching I came across a nice b18a motor that I'm currently stripping down and will be taking it to school to have it honed and hot tanked.
My main question is the crank bearings and rod bearings that I have with the motor currently, should I just re-use them? I've heard that it's possible and if they are in good condition they will work just fine but want to double check.
Can't wait for this to be done
Old Oct 5, 2005 | 02:53 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: starting my ls/vtec build...replace or use the stock bearings? (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, after months of searching I came across a nice b18a motor that I'm currently stripping down and will be taking it to school to have it honed and hot tanked.
Can't wait for this to be done </TD></TR></TABLE>
If the mains look ok, you can re use them. As far a s the rod bearings go, get a set of b16a bearings from honda in the correct color, as they are a tri metal bearing and can take alot more abuse than the bi metal pr4 rod bearings
Old Oct 5, 2005 | 03:18 PM
Default Re: starting my ls/vtec build...replace or use the stock bearings? (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">
If the mains look ok, you can re use them. As far a s the rod bearings go, get a set of b16a bearings from honda in the correct color, as they are a tri metal bearing and can take alot more abuse than the bi metal pr4 rod bearings</TD></TR></TABLE>
Thanks for your response. B16a rod bearings will work with LS rods? never heard of that combination in the past
Old Oct 5, 2005 | 03:20 PM
onepoint6i's Avatar
Thanks for your response. B16a rod bearings will work with LS rods? never heard of that combination in the past </TD></TR></TABLE>
P72/3 are different. b16/B18a/B can be interchanged ..
Old Oct 5, 2005 | 03:37 PM
Default Re: starting my ls/vtec build...replace or use the stock bearings? (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">
P72/3 are different. b16/B18a/B can be interchanged ..</TD></TR></TABLE>
you can also use the factory coated gsr/itr rod bearings on the ls rods, you just need to get the rods re notched to run them, they are excellent bearings, and you will make a little more power due to less drag, but the b16a's will be fine though
mayfly
Mar 30, 2014 03:59 AM
95jdmej2
Aug 16, 2009 07:00 PM
blackcrx16
Oct 15, 2007 06:45 AM
b18ek670
26
Aug 31, 2006 10:11 PM
ThirdGenLSR209
Jan 23, 2004 02:53 PM
