clutch slipping
Old Oct 5, 2005 | 02:03 PM
jonathan13's Avatar
Default clutch slipping
I just put a new clutch in my 94 del sol.. its a jdm b16a engine.. when i speed shift it the rpms shoot up but it doesnt feel like i am catching or spinning.. i cant tell if my tires are so bald they are just spinning or if it's the clutch.
If it is the clutch, what could be causing this? It's a brand new stock clutch... it feels really soft on the pedal.
Any help is appreciated. thanks
Old Oct 5, 2005 | 02:42 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: clutch slipping (jonathan13)
Did you break it in first?
Old Oct 5, 2005 | 02:45 PM
jonathan13's Avatar
Default Re: clutch slipping (SkoundrelUSA)
yes
Old Oct 5, 2005 | 02:46 PM
turbotime's Avatar
it might just need some break in, or it could be your master/slave cylinder going/leaking
does it grind or have trouble going in gear and does the pedal stay on the floor or come up slowly? if so its prolly the cylinders
otherwise its prolly just breakin, you need to drive 300-400miles stop and go to break in a clutch, or at least thats what my clutch said
Old Oct 5, 2005 | 02:56 PM
jonathan13's Avatar
Default Re: (turbotime)
the person's dad who was helping me swap in my motor had to take apart my slave cylinder and get rust out of it and he said that i would probably need a new one so could that be the problem? thanks.
Old Oct 5, 2005 | 03:40 PM
turbotime's Avatar
Default Re: (jonathan13)
i could be either the master or the slave, they both go on hondas, you might as well replace both, also before you do that check the clutch fluid level..
Old Oct 5, 2005 | 03:42 PM
AbitAvenger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonathan13 &raquo;</TD></TR><TR><TD CLASS="quote">the person's dad who was helping me swap in my motor had to take apart my slave cylinder and get rust out of it and he said that i would probably need a new one so could that be the problem? thanks.</TD></TR></TABLE>
DenisR
Feb 19, 2016 05:09 PM
Youshady2
Oct 21, 2013 01:54 PM
yunebug
Jun 15, 2010 07:29 AM
94civicgsr
Dec 25, 2007 06:29 PM
iwreakhavoc
Jun 3, 2005 10:47 AM
