swap help
Old Oct 5, 2005 | 01:49 PM
Pure Sol's Avatar
Default swap help
I have a B16a3 in a 95 del sol (originally D16z6) with ctr pistons and cams, msd sci, hondata gasket, header, aem cai, no knock sensor will be wiring that in tonite, p30... sounds like a subaru, and runs lean, get a code 43, sounds like a exhaust leak or (as a friend put it) 2 cylinders firing at the same time....can anyone point me in a direction to solve this? checked all injectors and all have 11.7 ohms, fuel regulator is good, fresh filter, cleaned all contacts on cap and rotor...at wits end...grateful for any help...
Old Oct 5, 2005 | 01:54 PM
Luserkid's Avatar
Default Re: swap help (Pure Sol)
Hows your timing?
Old Oct 5, 2005 | 02:39 PM
Pure Sol's Avatar
Default Re: swap help (Luserkid)
seems to be right on no problem at all....checked and rechecked that over and over....thinkin of runnin a p28 ecu, but don't know what chip to put in it...any suggestions????
Old Oct 5, 2005 | 02:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
check your firing order.
Old Oct 5, 2005 | 02:48 PM
Pure Sol's Avatar
Default Re: swap help (boostedcivicsir)
checked....1342??
Old Oct 6, 2005 | 08:49 AM
Pure Sol's Avatar
vacuum lines, nuts and bolts, all seem good....im losing paitence....help
Old Oct 6, 2005 | 09:16 AM
Mr. Badwrench
Old Oct 6, 2005 | 05:44 PM
Pure Sol's Avatar
yeah timing is right on...the questions were for any other suggestions, i should have spaced that more....im gonna pop the valve cover off tomorrow and make sure the cam gears are lined up....i couldn't wire the knock sensor in but that shouldn't make a difference except for VTEC and i can't go past 3000 rpms because of break-in....so any other suggestions are welcome and ill let you know more.
Old Oct 7, 2005 | 03:52 PM
Pure Sol's Avatar
i need a TB gasket for a B16A3 but my parts stores suck and honda won't have one for a week any ideas???
Old Oct 7, 2005 | 07:40 PM
93Civac's Avatar
MAke sure your injectors are firing. You may be getting power but they may be clogged or just stuck. Try unplugging them one at a time while the engine is running. If you unplug one and it the car doesnt react then it may not be firing. I had this happen with two of my injectors and it sounded about the same. I replaced the two that werent working and have had no problems since.
Old Oct 9, 2005 | 05:40 AM
Pure Sol's Avatar
Default Re: (93Civac)
alrite ill give that a whirl and let you know what i come up with.....quick question if i put a B18B1 TB on a B16A3 what throttle body gasket do i need?
Old Oct 13, 2005 | 04:44 AM
Pure Sol's Avatar
Default Re: (Pure Sol)
got out there last night and wired up the knock sensor,unplugged injectors, checked all vacuum and wiring diagrams, still sounds like exhaust leak or a good running scoobie...maybe it just runs like that? any other ideas?
Old Oct 14, 2005 | 03:15 PM
Pure Sol's Avatar
is anyone running a MSD SCI ignition? maybe supposed to run like this?
Old Oct 19, 2005 | 08:28 PM
Pure Sol's Avatar
still trying to figure out my WRX sounding problem(only when its warmed up), car drives fine checked spark and good wires, cap, rotor, plugs. Ive been told that the 4-1 header i have on there will make it sound like what i have. Anyone care to agree with that? Really got my stomach in a knot, all the horror stories ive read on here about blown pistons and all, so im looking for anything. Suggestions are welcomed and i will double check everything and anything thrown at me.
Modified by Pure Sol at 4:15 PM 10/20/2005
vteckid86
Jan 3, 2018 02:19 PM
poncejose334
Sep 8, 2009 07:18 AM
ctownintegra
Mar 21, 2008 07:36 PM
supereg2
Mar 21, 2008 09:33 AM
dElSleepiE
Jan 20, 2005 05:09 PM
