Planned setup for rebuild B18c1
Old Oct 5, 2005 | 01:42 PM
redGSRguy's Avatar
Default Planned setup for rebuild B18c1
I'm tired of driving around burning oil so I am going to get the engine rebuilt. Here is my planned setup any comments on what to improve would be appreciated. I plan on buying all the parts and taking it into a shop.
81.5 mm jdm itr pistons(p73) on stock gsr rods
arb rod bolts
aebs head studs
rocket m22s/ti retainers/g1 springs
blox IM (aebs?)
maxbore my gsr tb or purchase itr tb
comptech icebox/stock itr intake arm
act hdss/fidanza fw
new cat
new b-pipe(t1r?)
p28/ob2->1 harness/hondata
edit:
hondata im gasket
supertech nitrided valves (dished or flat face?)
Full gasket kit
acl bearings?
stuff I have:
buddy club cam gears
jdm itr valve cover (bling bling)
Anything I am missing? I hope to start ordering while the other car is in the shop and once that comes out send my car in.
Modified by redGSRguy at 10:56 AM 10/6/2005
Modified by redGSRguy at 2:14 PM 10/6/2005
Modified by redGSRguy at 3:23 PM 10/6/2005
Old Oct 6, 2005 | 05:49 AM
CNSK's Avatar
Default Re: Planned setup for rebuild B18c1 (redGSRguy)
I think your set up is right.....Just make sure you get all new gaskets for every inch of the motor....
Old Oct 6, 2005 | 07:57 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Planned setup for rebuild B18c1 (CNSK)
Are you going to be using stock sleeves? 81.5mm is a 0.020 overbore, which is the maximum Honda recommends on stock sleeves, for fixing damage to existing sleeves.
Old Oct 6, 2005 | 08:12 AM
SOHCVTECx2's Avatar
like what CNSK says buy all new gaskets for your block, new bearings, rod bolts i say stick with stock, and for the head studs go APR headstuds. Other than that its a good setup.
Old Oct 6, 2005 | 09:55 AM
redGSRguy's Avatar
Default Re: Planned setup for rebuild B18c1 (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Are you going to be using stock sleeves? 81.5mm is a 0.020 overbore, which is the maximum Honda recommends on stock sleeves, for fixing damage to existing sleeves.</TD></TR></TABLE>
Ya. I was going to stay stock sleeves w/no head work since that would be another 2k or so. You think it will be bad to push the limit? Usually shops will know what gaskets/seals to replace? Or should I just call up the dealership and tell them I need all the seals/gaskets for a rebuild.
Old Oct 6, 2005 | 10:06 AM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">Ya. I was going to stay stock sleeves w/no head work since that would be another 2k or so. You think it will be bad to push the limit? Usually shops will know what gaskets/seals to replace? Or should I just call up the dealership and tell them I need all the seals/gaskets for a rebuild.</TD></TR></TABLE>
It's fine, I was boosting 18psi on my stock sleeves bored to the same as yours. I was just curious. Anyway, yes the shop will know what to replace. I would hope they would know.
They will probably use a Honda gasket kit. You should get one yourself and give it to them. I forgot how much it was. It was a little pricey, but it included everything you'll need in terms of gaskets for a rebuild. There are two kits available. One is the basic one with just valve cover gaskets, maybe a head gasket, and some grommets. Then there's the big one with the gaskets you'll need for a full rebuild. Make sure you get that one.
Old Oct 6, 2005 | 02:04 PM
Cliffjumper2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">I'm tired of driving around burning oil</TD></TR></TABLE>
so am I...
if I don't trade my teg for something else; I'll probably do a rebuild this winter as well.
update us with how it turns out, and good luck
Old Oct 6, 2005 | 02:20 PM
redGSRguy's Avatar
Default Re: Planned setup for rebuild B18c1 (Palmy Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">maybe get your head rebuilt too... valve seals could be a cause of burning oil, make sure you get new rings with the pistons.</TD></TR></TABLE>
Ya someone told me it might be the vavle seals, don't remember exactly what my compression numbers were, just that cylinder 2 was low. I figured if I was going to get it opened up to fix I might as well upgrade some parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cliffjumper2 &raquo;</TD></TR><TR><TD CLASS="quote">so am I...
update us with how it turns out, and good luck </TD></TR></TABLE>
My motto was if your going to do it do it right, but since I realized headwork would be another ~1.5k I figured I'll just get the car running decently and buy my buddies sti when he gets a new car.
Old Oct 6, 2005 | 03:02 PM
My motto was if your going to do it do it right, but since I realized headwork would be another ~1.5k I figured I'll just get the car running decently and buy my buddies sti when he gets a new car.</TD></TR></TABLE>
I'm planning on picking up a complete itr head with manifold to mate to my gsr bottom end replacing all gaskets/rings/seals in the process.
I already picked up the 97 itr ecu.
This should be a nice stockish setup with good perfomance at minimal cost, including the reselling of my gsr head which is in good condition.
That's if i decide to keep my teg longer.
The buring oil is annoying more than a serious issue.
Old Oct 7, 2005 | 05:33 PM
redGSRguy's Avatar
Anyone know if it would be cheaper to rebuild it with stock parts and go jrsc? I need to stay out of the F/I forum, I am getting second thoughts.
Old Oct 8, 2005 | 05:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know if it would be cheaper to rebuild it with stock parts and go jrsc? I need to stay out of the F/I forum, I am getting second thoughts.</TD></TR></TABLE>
uhoh....you don't want to open up that can of worms
there was a great thread (pages and pages long) on the integra forum a year or two ago regarding the jrsc, pros and cons. It had excellent information; I suggest looking it up.
A used jrsc setup could be had for $1500. Yet, most of the people I speak to, if they had to do it over again would go turbo instead of jrsc, due to it it being more efficient....also the heat buildup with that a water cooler with the jrsc is excessive.
The coolers are expensive....
at least this is what I've read here and in FI
there's like a 20 page thread on the jrsc over in FI
Old Oct 26, 2005 | 02:48 PM
redGSRguy's Avatar
Anyone have any other suggestions before I start buying from the board sponsers?
Old Oct 27, 2005 | 10:36 PM
redGSRguy's Avatar
Anyone?
SiR-G DC
430
Aug 28, 2013 05:59 AM
mac_24_seven
Jul 25, 2006 06:20 PM
iH8RICERZ
17
Mar 3, 2006 01:08 PM
redGSRguy
Oct 26, 2005 04:32 PM
