ABS light and idling problem
Old Oct 5, 2005 | 01:40 PM
defaced8's Avatar
Default ABS light and idling problem
I just bought a 97 Accord LX V6. A couple days after I bought it, the ABS light started to come on and stay on for as long as the car is on. Once I turn on the car, it comes on a couple seconds later and stays on until the car is shut off. I've checked the fluid, but that's the only thing I personally know how to check, so that's all I looked at.
Also, when the car is idling, either in P or in D, it idles kind of rough. Any ideas? Spark plugs? Timing?
Any help would be appreciated. Thanks in advance.
Old Oct 6, 2005 | 04:45 AM
JimBlake's Avatar
Default Re: ABS light and idling problem (defaced8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by defaced8 &raquo;</TD></TR><TR><TD CLASS="quote">Spark plugs? Timing?</TD></TR></TABLE>When was the last time you checked/changed the plugs? Plug wires, cap, rotor?
You can read ABS error codes by jumpering the SCS service connector, search for the details, 'cause your '97 probably isn't the same as my '98. When you jumper that, the ABS lamp will flash the code...
jordan_civic
Aug 31, 2007 07:36 PM
Type_R_Lover
Nov 7, 2006 09:10 AM
310HPS2k
Sep 25, 2005 06:09 AM
THE94GSR
Jun 8, 2003 03:53 PM
GSblueRacing
May 6, 2003 09:21 PM
