will 17x7.5" fit on a dc2?
Old Oct 5, 2005 | 01:24 PM
2k1 SSM GSR's Avatar
Default will 17x7.5" fit on a dc2?
i was under the impression that 7" was as wide as i could go. i've owned 17x7, 18x7, and 15x7 wheels, i have never owned 7.5.
i am asking this because i am looking at getting some rota d2's but they smallest they come in is 17x7.5".
they also come in thiese offsets.
+25
+35
+40
+45
+48
could they fit?
Old Oct 5, 2005 | 02:35 PM
Default Re: will 17x7.5" fit on a dc2? (2k1 SSM GSR)
somebody? anybody?
Old Oct 5, 2005 | 03:12 PM
CB7.v2's Avatar
probably 45 or 48. enter your car specs at http://www.tirerack.com when selecting wheels. click closeup after you select various brands of 17x7.5 and you will see the suggested offset. the higher the number, the deep inward the wheel will be, the less chances of rubbing the fender. it will also tell you the correct tire size.
Old Oct 5, 2005 | 03:59 PM
Autoworks's Avatar
Yes the 17 will fit fine, you can get anything +40 or more in offset, 45 being ideal. If the car isn't lowered you can use a 215/40-17, if lowered use a 205/40-17
Old Oct 5, 2005 | 07:41 PM
Default Re: will 17x7.5" fit on a dc2? (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">Yes the 17 will fit fine, you can get anything +40 or more in offset, 45 being ideal. If the car isn't lowered you can use a 215/40-17, if lowered use a 205/40-17 </TD></TR></TABLE>
sounds good. yes the car is lowered.
ps. what would be the deepest offset i could use? 45?
gt99
Sep 14, 2017 11:26 PM
jdm2000gsr
Aug 23, 2012 05:48 PM
HONDA_TEG
Jan 23, 2009 03:28 PM
baiwldrnner
Honda Civic (2001 - 2005)
Aug 9, 2007 05:12 AM
FrostyDC4
Oct 1, 2004 05:40 PM
