How do I access the stock sub in Gen 4's
Old Oct 5, 2005 | 12:33 PM
94Vtecluder's Avatar
Default How do I access the stock sub in Gen 4's
How do I access that speaker in the middle of the seats on the gen 4? I tried that lil keylock thing in the car and opened up the panel on the inside under the window but that didn't seem to do much. I need to disconnect it for now cuz it's blown.
Old Oct 5, 2005 | 12:41 PM
Lewdin' Incognito's Avatar
Default Re: How do I access the stock sub in Gen 4's (94Vtecluder)
I think you have to get to it from the rear(trunk), but mine doesn't have it. If you go to hondahookup.com, you can get the FSM(.pdf) to tell you how to get to it. You have to register for the site, but it's free.
Old Oct 5, 2005 | 12:47 PM
manman's Avatar
remove lower rear seats theres 2 clips each side of the seat just pull the tab out then unbolt the rear upper seat and slide upward has a clip that you have to slide back on when u put it on then remove the two plastic retaining screws holding the plastic cover on and bam u have access you can also remove the two plastic screws in the trunk holding the carpet plastic board on and just disconnect it then put hte board back on
Old Oct 5, 2005 | 03:58 PM
Turbo-GSR1287's Avatar
Default Re: How do I access the stock sub in Gen 4's (manman)
sry to be a thread jack but this sub only came in the Vtec 4th gen correct?
Old Oct 5, 2005 | 04:43 PM
Default Re: How do I access the stock sub in Gen 4's (-95LudeSI-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -95LudeSI- &raquo;</TD></TR><TR><TD CLASS="quote">sry to be a thread jack but this sub only came in the Vtec 4th gen correct?</TD></TR></TABLE>yes
vietkazie
Nov 18, 2006 05:45 PM
l3uddhab0y
Apr 21, 2006 03:46 PM
fastboy501
Nov 29, 2005 09:28 PM
ej1times
Oct 2, 2004 05:04 PM
151 Proof
Apr 2, 2003 09:26 AM
