fuel injector cleaner.... helppppppppppp
Old Oct 5, 2005 | 12:14 PM
hlee5363's Avatar
Default fuel injector cleaner.... helppppppppppp
anyone put some fuel injector clearner in their car before... i put it on my civic before when it was idleing funny and it seemed to solve the problem... and recently i sold my civic and picked up an gsr... and i put a bottle in my gsr... seems to give me problems... like my engine light came on... and also starts funny... sometimes it runs rough for like 30 sec and then runs fine again... anyone knoe why ???
Old Oct 5, 2005 | 01:00 PM
suzawa94's Avatar
Default Re: fuel injector cleaner.... helppppppppppp (hlee5363)
maybe that injector cleaner is fucked up. while the cleaner made it's way to the injectors it must have fucked with one of them. that's probaly why the CEL came up. it's probaly a misfire code. try using the tank of gas you have now and fill up later. you might want to change your fuel filter too. if that doesn't work, i would try and listen to the injector pulse-see if the injector is bad or not.
Old Oct 5, 2005 | 03:27 PM
JAXTUNER's Avatar
If the mix was to strong , sometimes it gets to the 02 sensors and the spark plugs, take them out and check them , if the plugs are ok reset the ecu...good luck.
Old Oct 5, 2005 | 11:02 PM
hlee5363's Avatar
how do i just check the spark plugs.. can u just look at them and see if they are bad or not ???
Old Oct 5, 2005 | 11:14 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hlee5363 &raquo;</TD></TR><TR><TD CLASS="quote">can u just look at them and see if they are bad or not ???</TD></TR></TABLE>
Yes.
Old Oct 6, 2005 | 07:20 AM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hlee5363 &raquo;</TD></TR><TR><TD CLASS="quote">how do i just check the spark plugs.. can u just look at them and see if they are bad or not ???</TD></TR></TABLE>
You either see fuel on them or you don't lol
JayCook
Jan 11, 2013 09:16 PM
crj_lll
Mar 30, 2006 09:42 AM
m1nh
Jul 4, 2005 10:50 PM
EFz6er
Apr 1, 2005 02:11 PM
racerboyb18c
Jan 9, 2003 01:30 PM
