where to buy low temp thermostat?
Hello.
Just prepping my new race motor to go into the Civic (its a B18A LS motor). I'd like to put a low temp thermostat (not the fan switch, the actual thermostat) in there (maybe around 160 degree?)....
Anyone know where I could order one from?
How about a 20-30 psi oil press switch? I have a gauge, but would like to install a BIG RED light which would go off and alert me to low oil pressure situation. The stock switch goes off at like almost 0 psi (usually too late by then). And during the road races, there just is not enough time to watch the gauge all the time....
Thanx for the info.
Todd
d15b7@aol.com
Thanx for the info.
Todd
d15b7@aol.com
Hi Todd.......
Autometer Sending units for Pro Lights (likely just a switch!)
Jegs part numbers......
105-3242 30 psi low pressure (will come on during warm idle BTW!)
Low temp thermo, should be able to get a 180 degree at Autozone. But as you know under race conditions, once thermo is fully open, it don't matter, esp at 200+ degrees.
JD95hatch
Aug 22, 2004 01:00 PM
sirminder
Dec 17, 2003 02:52 PM
