is this the fuel pump or fuel level unit?
i am tring to figure out why my 90 integra keeps dieing, i no longer hear the fuel pump come on when i turn the key. i removed the rear seat and un screwed the 3 phillips screws and removed the cover. i tapped the ringg and removed the unit but this dosent look like a fuel pump. is this the pump or is the pump somewhere else? i used a light tester and this unit is getting power. i hope i dont have to buy a new fuel pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h0ndavtec »</TD></TR><TR><TD CLASS="quote">i am tring to figure out why my 90 integra keeps dieing, i no longer hear the fuel pump come on when i turn the key. i removed the rear seat and un screwed the 3 phillips screws and removed the cover. i tapped the ringg and removed the unit but this dosent look like a fuel pump. is this the pump or is the pump somewhere else? i used a light tester and this unit is getting power. i hope i dont have to buy a new fuel pump</TD></TR></TABLE>
did you check your main relay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h0ndavtec »</TD></TR><TR><TD CLASS="quote">would i still be getting a power siginal in that plug that plugs into the unit if my main relay was bad? where is the main relay and how do i check it</TD></TR></TABLE>
not sure about the power thing but if the fuel pump is not coming on then i would definately check the relay, the relay location i am not sure of, check over at g2ic to verify it
ok, from the pictures i got from the shop manual, the unit i am looking it is not the fuel pump. does it matter that my integra is a 4dr? the unit i am looking at has the floaty thing for the fuel guage but no pump or strainer, where can i find it cuz the manual say is should be where i am looking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h0ndavtec »</TD></TR><TR><TD CLASS="quote">ok, from the pictures i got from the shop manual, the unit i am looking it is not the fuel pump. does it matter that my integra is a 4dr? the unit i am looking at has the floaty thing for the fuel guage but no pump or strainer, where can i find it cuz the manual say is should be where i am looking</TD></TR></TABLE>
the fuel pump is in the gas tank, did you test the main relay? the only way you can test a relay is for continuity
^^^ if you have power going to the fuel pump, check that you have ground at the main relay. i'm not sure what pin it is, but on 96 dc2 it's pin #3. wait, if you have the shop manual shouldn't it tell you how to diagnose? there should be a flow chart just for the main relay
