monster tach or shift light
Old Oct 5, 2005 | 06:40 AM
01_prelude's Avatar
Default monster tach or shift light
i have a question which would you perfer in your prelude a auto meter monster tach or a auto meter shift light with the pills. i dont under stand the whole monter tach right there in your window when you can use a shift light. let me know what you guys perfer thanks.
Old Oct 5, 2005 | 06:45 AM
maks's Avatar
Default Re: monster tach or shift light (01_prelude)
hmmm... care to enlighten me as to their usefulness? I don't have either and I still manage to drive my car...
Does a shift light tell you the optimal moment to shift gears? Or does it light up when you've over-reved and are damaging your engine?
Old Oct 5, 2005 | 06:52 AM
H22a T13's Avatar
Default Re: monster tach or shift light (CluelessDrac)
You set it to the best rpm for each gear to shift, then when you get to it the yellow light lights up.
Old Oct 5, 2005 | 07:24 AM
maks's Avatar
Default Re: monster tach or shift light (H22a T13)
That's rather primitive, as depending on your driving/accelerating and weather conditions, your "best RPM" can significantly change.
I guess it's just for bling, or maybe just for when you go to drag strip.
Old Oct 5, 2005 | 07:33 AM
Lewdin' Incognito's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22a T13 &raquo;</TD></TR><TR><TD CLASS="quote">You set it to the best rpm for each gear to shift, then when you get to it the yellow light lights up.</TD></TR></TABLE>
That is the "ideal" use for it - in a drag environment. However, it's about as useful as a giant aluminum wing on a neon for driving.
Old Oct 5, 2005 | 08:16 AM
VisPreludeVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01_prelude &raquo;</TD></TR><TR><TD CLASS="quote">i have a question which would you perfer in your prelude a auto meter monster tach or a auto meter shift light with the pills. i dont under stand the whole monter tach right there in your window when you can use a shift light. let me know what you guys perfer thanks.</TD></TR></TABLE>
why go autometer? cause everyone has them? Stewart warner has some sick gauges you might want to check out. The one tach is digital with LCD shift light, its about as big maybe a little smaller then the autometer shift light and looks alot cleaner
Old Oct 5, 2005 | 08:23 AM
mgags7's Avatar
or you could go with neither.....your tachometer works fine to tell you where to shift....
not its not 100% accurate.....but you will get a feel for it....
dont put big ugly things that dont belong into preludes....
ken00si
10
Sep 7, 2005 10:11 AM
whytTypeR
Mar 28, 2005 04:47 PM
mrtoastyjr
Jun 17, 2004 09:07 AM
RUBZERK
Mar 3, 2004 07:53 AM
01PYTypeR#1140
May 20, 2002 09:29 AM
