Squealing noise from tranny
Guys and girls, thanks for your help.
My RRR is a 2000 which came with an aftermarket replacement tranny of some sort. The tranny has approximately 80,000 kms on it. 2-3 synchro needs to be replaced, but clutch still works fine.
During idle, occasionally an intermittent squealing noise comes from the tranny. Sometimes you can trigger the noise after you take your foot off the clutch. The noise doesn't fade in or out, it's either on or off.
Could it be the throwout bearing or input shaft bearing?
Cheers,
Eric
Cheers,
Eric
From: around the corner to the left ... no, your other left
try this link https://honda-tech.com/zerothread?id=1377136 and see if some of those comments apply to you. Through this discussion, I found out that my problem was the tranny input shaft bearing not my throw out bearing. read the 3rd to last post by SMSP.
willyboyK20
Aug 23, 2004 05:27 PM
