Pic's Of My GSR Motor And Need Help In Gasket......LQQK!!!!!! LQQK!!!!!!
These are the pic's of my block n head i have a little problem when i put the head on i went to turn the pulley around to see if everything was ok i notice that the piston was hittin the head so i spoke to mike from Erick's racing he told me to put 2 head gasket on so i did and it wasent hittin the head anymore so i need ya'll help do u think is safely enuff to have 2 head gasket on or will it work fine i really need help i wanna get my motor on the car already and start breaking in it so if u have heard of anyone using 2 head gasket or have any experience about it let me know anything will help thanx.....
This is what my long block consist of so far....
GSR HEAD...
JUN cams stage 3..
JUN springs n retainers..
SKUNK 2 cam gears..
SKUNK 2 intake manifold..
JG throttle body 65mm..
RC injectors 440..
AEM fuel rail n regulator..
GSR BLOCK..
GOLDEN EAGLE sleeves..
ENDYN piston 85mm 13.8 compression..
CROWER rods..
CROWER crank 92mm..
GSR HEAD...
JUN cams stage 3..
SKUNK 2 cam gears..
RC injectors 440..
GSR BLOCK..
CROWER rods..
CROWER crank 92mm..
Get a hold of Cometic...they make gaskets in different thickness'. I dont know about using 2 gaskets, the Cometic ones work pretty well.
ya I've had to do that before and it worked. however if you would like to do it correctly then: take a depth gauge and measure how far the piston is ouf the hole.
say it is .020 in. out then call cometic for a gasket that is .020 + .030=.050 in. thick. and there you go, should have no problems what so ever. I have this happen sometimes when stroking things are thrown a little of or addition of several things like crank little off, too much decking of block, rod length mis calc by thousands, etc. But don't worry; but first find out how far out the piston is out of the hole. don't forget stock honda pistons usually sit about .010in. in the hole and stock gaskets are .028in. good luck and pm me for any other questions
so you would recomend going with two head gaskets........ when you double up on a gasket are you not affraid of the gasket shifting and causing a leek? I was tought through my ASE cert. class that doubling up can cause problems........... is this not true?
As a prior honda, lexus, toyota tech and engineer I am aware of this. I've done it in the past as a nessecity and worked, but that is not the correct way to fix this. your right but as for shiffting, the dowels do a good job. But lets do things right and not twice.
. he should get the correct sized gasket and have no worries.
Thank you. I honestly have to say you are one of the most mature person on Honda-Tech. Sorry im just so used to "well I think my friend did it on his car soooo it should work for you" you back your answer up with personal experience and a true recomendation. Thank you cptengineer
belive me i've been in quit a few jams, If i know something i'll let you guys know and wont guess, I know engines can be expensive specially when your young.
good luck to you and your ASE certs.
nope. that would not be how to fix it. Don't forget the piston should be a few thousands of an inch down the hole. Plus smaller chambers make for good quench area. Lets fix it right and not guess at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cptengineer »</TD></TR><TR><TD CLASS="quote">nope. that would not be how to fix it. Don't forget the piston should be a few thousands of an inch down the hole. Plus smaller chambers make for good quench area. Lets fix it right and not guess at it.
Good info right here, do it once and do it correctly, dont just put a bandaid on the problem, its nice to see another person in this forum that knows their ****
</TD></TR></TABLE>Good info right here, do it once and do it correctly, dont just put a bandaid on the problem, its nice to see another person in this forum that knows their ****
Why are your pistons hitting your head? Did you have your head or block deck milled? An as fasr as gackets go, using 2 head gaskets is ok, but you can also just get thicker head gaskets instead or using 2. Are you boosting it? What do you want your compression ratio to be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calrya31 »</TD></TR><TR><TD CLASS="quote"> Are you boosting it? </TD></TR></TABLE>
considering what section he posted in and after looking at those pistons you really have to ask that?
yea i took the block to the machine shop for they can deck it a little but i guess they over did it so thats y is causing the problem, am only gonna use the 2 head gasket to break in the motor cuz everythin in the block is new then after the car got the miles put in am gonna get a thicker gasket from cometic i havent got it cuz they said it takes like 3 weeks for me to receive so if anyone got one or know where i can get one let me knoww.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT »</TD></TR><TR><TD CLASS="quote">
Good info right here, do it once and do it correctly, dont just put a bandaid on the problem, its nice to see another person in this forum that knows their **** </TD></TR></TABLE>
ya and two headgastkets is really a permanent fix
I may be way off here but i think lg_r32 is right. I remember when i was building my old motor,i went to pick up my head from Alaniz (joe) he told me i might have clearance issues with aftermarket pistons on the edges. He told me if i do to let him know and he will open up the clearance.
im guessing right at that edge is where your piston is hitting. Notice yours dome comes all the way out to the edge.
Hope that helps
Modified by ArinX at 6:01 PM 10/7/2005
Hope that helps
after you get the thicker head gasket, it might not be a bad idea to lock the vtec rockers, adn clay the motor. measure how close you come with the larger lobe is in effect.
dont wanna go boom the fist time you go VTAK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y me »</TD></TR><TR><TD CLASS="quote">yea i took the block to the machine shop for they can deck it a little but i guess they over did it so thats y is causing the problem, am only gonna use the 2 head gasket to break in the motor cuz everythin in the block is new then after the car got the miles put in am gonna get a thicker gasket from cometic i havent got it cuz they said it takes like 3 weeks for me to receive so if anyone got one or know where i can get one let me knoww.....</TD></TR></TABLE>
I dont think they just accidently "over did it". Going with two head gaskets sounds like a ok fix for now. I would def get a cometic gasket as soon as I could though.
hit up trackspeedracing.com he should be able to get u a head gasket quick.. got mines in 2 days
his h-t name on here is trackspeedracing shoot him a pm.. im sure he'll be able to get u a gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cptengineer »</TD></TR><TR><TD CLASS="quote">As a prior honda, lexus, toyota tech and engineer I am aware of this. I've done it in the past as a nessecity and worked, but that is not the correct way to fix this. your right but as for shiffting, the dowels do a good job. But lets do things right and not twice.
. he should get the correct sized gasket and have no worries.</TD></TR></TABLE>
yeah!!!!!!! for the right way
. he should get the correct sized gasket and have no worries.</TD></TR></TABLE>yeah!!!!!!! for the right way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH »</TD></TR><TR><TD CLASS="quote">after you get the thicker head gasket, it might not be a bad idea to lock the vtec rockers, adn clay the motor. measure how close you come with the larger lobe is in effect.
dont wanna go boom the fist time you go VTAK</TD></TR></TABLE>
I have to agree with this!^^^ Rather be safe then sorry! Nice build
