What clutch should I go with
Old Oct 4, 2005 | 08:26 PM
arrojj's Avatar
Default What clutch should I go with
Well Im planing to get a new clutch and fly wheel next week should i go with a Exedy stage 2 normal thickness clutch or an ACT stage 3 clutch both with an 9 or 11 pound fly wheel. I am planing to go turbo next year. and so far i have Intake, skunk2 IM, 2 1/4"cat back exhaust, GSR TB and 4 into 1 header all on an b18b motor.appreciate any coments and suggestions.
Old Oct 4, 2005 | 08:57 PM
fucktrial's Avatar
**** exedy i got one it sucks ***. get an ACT keep the stock flywheel though, the rev wil be too crazy and especially if you planning you to turbo you dont wanna rise rpm so quickly
Old Oct 4, 2005 | 09:20 PM
ernald711's Avatar
Default Re: (fucktrial)
^^^^ someone's made some bad decisions.
i recommend the Action 1ks clutch. smooth engagement, probably 20% stiffer than stock, and it's kevlar! a lot of ITR run this clutch. for the flywheel i'm stock cause i didn't wanna throw off my balanced crank.
Old Oct 4, 2005 | 09:55 PM
Kendall's Avatar
I usually have a clutch shop build one for me. It usually ends up cheaper as well.
Old Oct 4, 2005 | 10:01 PM
SGVridgerunner's Avatar
Default Re: (Kendall)
agreed!
I had Clutch Specialties in Orange County, CA build an ACT clutch kit with a stock flywheel machined down to 12 lbs for my D16Z6. 120,000 miles later, no problems, and it was LESS THAN HALF of what a Clutch Masters kit would have cost me.
Old Oct 4, 2005 | 10:09 PM
Kendall's Avatar
Default Re: (SGVridgerunner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SGVridgerunner &raquo;</TD></TR><TR><TD CLASS="quote">I had Clutch Specialties in Orange County, CA build an ACT clutch kit with a stock flywheel machined down to 12 lbs for my D16Z6. 120,000 miles later, no problems, and it was LESS THAN HALF of what a Clutch Masters kit would have cost me. </TD></TR></TABLE>
My last one was from Asheville Clutch And Brake in Asheville NC. It had a 60% holding capacity over stock with about half the stock pedal effort. I mated it to an Exedy flywheel and it was the best combo I've ever felt (excluding the ATS carbon setup).
s2k_8582
Honda S2000
Jul 20, 2011 12:09 AM
93CivNewB18
Jan 8, 2009 02:06 PM
efrex
Mar 9, 2005 06:01 PM
danny98r
Jun 24, 2004 12:15 PM
Toretto
Feb 25, 2003 08:51 AM
