DA Interior Lighting
at night when i turn on the lights not everything lights up on the inside...the cluster does and the buttons under it...but the climate control and ashtray dont light up...neither does the green light on my AC button (when its on) or anything ...help me plzzzz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegraX »</TD></TR><TR><TD CLASS="quote">nah...i used to be able to pund on my dash with my fist ad make it work for a min but i cant even do that anymore hahaha</TD></TR></TABLE>
Pounding on the dash could very well break the bulbs. But it sounds like you have loose and/or corroded wires.
very common problem on DA's
not the bulbs/fuses
when I had this problem on each of my DA's (3 of them), I took it apart, and cleaned all the connectors/wires.
sometimes this would work, and sometimes it didn't
but common problem
not the bulbs/fuses
but common problem
Did you change the bulbs? When i got my DB1 both climate bulbs were burned out and half the cluster ones were too. It's a PITA to change the climate control ones also the cluster. Every time i take the cluster out in either of my G2's i end up scraping my hand up trying to take out the damn speedo cable.
I'm gonna vote for connections being bad. I usually have to pound the left side of the indtrument cluster to get the light that shines on the tach and temp guage needles to light. Also have the problem with the AC light. Usually have to smack the dash above that too.
DanGAvery
Nov 30, 2018 04:35 PM
Flatland2D
Apr 13, 2007 11:38 AM
