climate control issues.. searched
okay so a few months back i fell asleep on the i5 and rear ended a truck.. nice job dick.
anywho, i've since then fixed my front end but the remaining issue seams to be the climate control. 1 of the bulbs i out, or something else but nothing works. i push in the buttons try to do everything but no air comes out anywhere. i tried to take it out to see if everything i plugged in but the hazzard button just pops off instead of the entire thing coming out to get to the screw...
i searched but mostly found stuff on installing/removing...
any help appreciated.
-halo
-halo
I'll try and help. It has been a long time since I have removed one. You need to remove the Hazard button and the Defrost button. Remove the 2 screws and then disconnect the temp control cable located under the glove box near the floor. Then carefully pop the unit out. It would be helpful if you used a panel removing tool (hook) to release the tabs that hold it in. If it is broken, I have a working one I'll let go cheap.
blkegcoupe
Aug 26, 2008 05:01 PM
ner0x
Jun 23, 2005 07:17 PM
zertoir
May 1, 2004 06:41 PM
Tomek
Oct 5, 2002 05:46 AM
