gt28r/71 - 48mm trim a/r 0.60
Old Oct 4, 2005 | 01:39 PM
jure's Avatar
Default gt28r/71 - 48mm trim a/r 0.60
is it possible to hit 400 whp number with that turbo ? on b16 engine..i saw that exist three different types of that turbo. 48mm, 52mm, 56mm trim.I can get alomst new 48mm trim, but only on condition that provided up tp 400whp.
check
are that whp numbers?
http://www.turbobygarrett.com/...1.htm
they say that supports up to 400whp, but with what size of compressor housing?
http://www.full-race.com/catal...d=504
my setup:
b16 stock bore, not sleeved engine..
eagle rods, wiseco 8.8 etc..
Old Oct 4, 2005 | 01:44 PM
andysila's Avatar
Default Re: gt28r/71 - 48mm trim a/r 0.60 (jure)
im assuming its w/ the 56 trim.
Why not a GT30r? or even a GT35r?
Old Oct 4, 2005 | 02:18 PM
jure's Avatar
Default Re: gt28r/71 - 48mm trim a/r 0.60 (andysila)
cause i can get it for 500 bucks.Turbo is almost new it has 3k miles..
Look at our drag race, as you can see we don't have here in slovenia(country near italy) real track to drag, so we need to arrange drag events on the street..
here's one video of my car...on the left side is venturi atlantique..
save as
http://www.mobisux.com/album/d...c.wmv
Old Oct 4, 2005 | 02:34 PM
andysila's Avatar
well if its legit, then go for it. money wise, i think $500 for one of those turbos is good, considering its "like-new".
but if your true power goal is 400 whp, then i say save up the money and get yourself a gt30 of some sort.
Old Oct 4, 2005 | 03:19 PM
jure's Avatar
Default Re: (andysila)
where do you think make gt30r boost on my setup?
b16 stock bore, 8.8 CR
Old Oct 4, 2005 | 03:30 PM
jure's Avatar
Default Re: (jure)
what about T3/60 Turbo, what trim what a/r will be best to find out max of my setup (stock sleeves)..this turbo has a good price.. what about spool??on b16 engine (stock bore, 8.8CR)?
Old Oct 4, 2005 | 03:32 PM
andysila's Avatar
im sorry, are you tryin to ask me when does boost kick in?.
i have almost the same setup as yours, a b16a2 from my em-1. gonna keep it stock bore but you never know what'll happen in the future (money-wise).
i was going to go with a gt28rs but then it only supports up to about 300 hp i think(?). so i decided to spend $100 more and get a gt30 that can easily support 300-500 hp.
Old Oct 4, 2005 | 03:49 PM
jure's Avatar
now i decided to go with t3/60 , becouse it's much cheaper than GT series.Ok, it's non ball bearing but, doesen't matter..I would like to see full boost at 4.5k RPM , what trim and A/R should i get..Don't forget i'm looking for 400-450whp ...
Here in europe you can get on every gas station 100 octane gas, min octane you can get in europe is 95.so we can get high hp numbers on pump gas than youbut it's damn expensive..today i refeel my civic and i payed for 39 liters (10.3 gal) almost 50 bucks(
Old Oct 4, 2005 | 10:14 PM
andysila's Avatar
t3/t60 is still good, will definitely meet your power goals.
Old Oct 5, 2005 | 12:40 AM
jure's Avatar
what a/r and trim should i get?
Old Oct 5, 2005 | 06:19 AM
Si Shane's Avatar
Default Re: (jure)
ok guys i want an arbitrary number so i wll change the entire way my projected setup will behave to make that... wait this doesn't make any sense at all....
Old Oct 5, 2005 | 06:38 AM
BlueShadow's Avatar
Default Re: (jure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jure &raquo;</TD></TR><TR><TD CLASS="quote">what about T3/60 Turbo, what trim what a/r will be best to find out max of my setup (stock sleeves)..this turbo has a good price.. what about spool??on b16 engine (stock bore, 8.8CR)?</TD></TR></TABLE>
The T3/T61 is what I would call the "poor mans" GT35R. You should check on http://www.evans-tuning.com in the dyno sheet forum and do searches for the T3/T61 or even the SC61 (SC6152E). Both of those can be bought with the GT35R cold side, it will just have the standard journal bearing and not the GT ball bearing center section (CHRA). For turbine a/r I would say go with a 0.63 a/r, and if at all possible ask for the T04S compressor housing since it will support more power. Those turbo's should reach bost by around 5500 or so RPMs, but if you look on Evans Tuning you can see for yourself on peoples dyno sheets.
jdmd16
Dec 22, 2005 06:35 PM
dester223
Nov 1, 2004 07:37 PM
2camsaam
Oct 1, 2002 09:24 AM
Double 06
Jul 10, 2002 01:35 PM
