gsr or ls tranny?
Old Oct 4, 2005 | 11:55 AM
FULLY_BUILT_NA's Avatar
Default gsr or ls tranny?
aight i got a 95 gsr. the gears are way too long for me.. i wanna swap in an LS tranny. my questions are
1)how much is each tranny worth?
2)will a clutch from the gsr fit the ls tranny?
3)will the redline be the same or go down to 7200?
4)anything else i need or just plug and play?
thanks, and this is for an all motor setup
Old Oct 4, 2005 | 12:00 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: gsr or ls tranny? (FULLY_BUILT_NA)
I think you have this reversed. The LS tranny's gears are much longer than the GSR. In fact, it has the longest gears of all the B-series.
LS = $200+
GSR = $500+
B16 = $600+
Yes
Redline remains the same. It is determined by your ECU/motor, NOT your transmission.
Plug and play. All B-series transmissions are interchangeable.
Old Oct 4, 2005 | 08:52 PM
fucktrial's Avatar
Default Re: gsr or ls tranny? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">I think you have this reversed. The LS tranny's gears are much longer than the GSR. In fact, it has the longest gears of all the B-series.
LS = $200+
GSR = $500+
B16 = $600+
what? i thought Ls had the shortest gear. cuz in my ls crx the gears were short as hell. and in my gsr it takes forever to go up. whats so special bout the b16 tranny?
Old Oct 4, 2005 | 08:55 PM
LoseRPunKx182's Avatar
http://www.allmotorhonda.com/t...s.htm
Old Oct 5, 2005 | 09:51 PM
Default Re: (LoseRPunKx182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.allmotorhonda.com/t...s.htm</TD></TR></TABLE>
yea... LS is shorter, the numbers are smaller.
Old Oct 5, 2005 | 10:06 PM
Danger's Avatar
Default Re: (FULLY_BUILT_NA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLY_BUILT_NA &raquo;</TD></TR><TR><TD CLASS="quote">
yea... LS is shorter, the numbers are smaller.</TD></TR></TABLE>
B16 / ITR trannies have the shortest gears .
Old Oct 5, 2005 | 10:26 PM
shamoo's Avatar
Smaller numbers do not mean shorter gears.
Old Oct 6, 2005 | 01:52 AM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: (shamoo)
kid ur wrong... LS has a long azz gear ratio. GSR tranny, ur RPM jumps hella fast. ur hittin vtec at 4500 doin 90 mph
Old Oct 6, 2005 | 05:46 AM
shamoo's Avatar
Default Re: (tekneshum2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekneshum2 &raquo;</TD></TR><TR><TD CLASS="quote">kid ur wrong... LS has a long azz gear ratio. GSR tranny, ur RPM jumps hella fast. ur hittin vtec at 4500 doin 90 mph</TD></TR></TABLE>
I hope you don't mean me.
Old Oct 6, 2005 | 06:20 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
I'll take your GSR tranny if you don't want it.
Old Oct 6, 2005 | 06:30 AM
LL2009's Avatar
Default Re: gsr or ls tranny? (Tim2179)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim2179 &raquo;</TD></TR><TR><TD CLASS="quote">I'll take your GSR tranny if you don't want it. </TD></TR></TABLE>
i saw it first
Old Oct 6, 2005 | 09:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLY_BUILT_NA &raquo;</TD></TR><TR><TD CLASS="quote">yea... LS is shorter, the numbers are smaller.</TD></TR></TABLE>
wow....
Old Oct 6, 2005 | 09:24 AM
95lstegman's Avatar
i'm kind of addicted to my LS trans. all new everything plus 4.40 final drive and ITR diff. i don't consider the gears too long. but then again i don't have a VTEC motor so my torque band is much more liveable. it's also a daily driver with LOTS of highway time. it sucks shifting all the time w/ short gears, and my motor can drive around at 1500rpm if i want it to in 5th gear. maybe that's the difference between you all and I (BTW for the rednecks, you all = ya'll).
ppg97ek
Sep 4, 2007 01:51 PM
95dc2teg
Oct 30, 2006 05:48 AM
H.A.R.T B18C1EG6
Apr 27, 2006 09:53 PM
riceburnah
Feb 1, 2005 05:00 PM
crazed_crx
Dec 4, 2003 07:28 AM
