TESTING WATERS Apexi Ball Bearing Turbo Kit!!!!!!!!!
Alrigth guys i'm thinking of changing my setup and here is what i have for sale.
Apexi Turbo Manifold (D-series but modded to fit B, ported and bolt holes longated)
Apexi Ball Bearing Turbo (NO SHAFT PLAY, NO OIL ANYWHERE i cant stress this enough)
Apexi 2.5 Downpipe With extra 02 bung with plug for it
Apexi Internal wastegate(adjustable)
Apexi oil drain flange with silicone drain tube
Apexi oil feed line stainless with all fittings
Apexi Filter, and pipe i made form 2.5 mandral bends and black silicone connector
Will bolt up to factor exhaust.
this is a great setup for any car. i see full boost at 4k of 10lbs shows 3600 in 5th but i liek to go by the other gears cause i dotn boost 5th.
I dynoed this kit on my d16z6 with 195,000 miles on it and i made 225 and 189 with it. here is graph to show allso this kit is A/C and P/S compatable. i have both
only engine bay pic i have now
can see some B series dyno graphs here
https://honda-tech.com/zerothread?id=516769
https://honda-tech.com/zerothread?id=363036
https://honda-tech.com/zerothread?id=713248
i'm looking to get around 1000 for everythign but i'm open to ALL offers no need to worry aout low ***** i'd get more pics up ASAP hit me up guys
yes it tis so far its gone 13.7 at 107 hope to hit 12's i need slicks thanks for bump gettin gpics tonight at the local meetting spot
this is a hot setup. i guarantee you will love this kit. Price is way underpriced. Someone should jump on it asap.
KevronsEG
Sep 20, 2009 01:46 PM
