da with front end wobble
I just started to notice a wobble in my front end, but only at slow speeds?? The tires are a little worn but all of the sudden? and only at slow soeeds? could this just be a balance issue, or like a LCA bushing?? any help would be apprechiated..
tie rod bushings.. same is happening with mine on my passanger side wheel, put it up on the lift and you can wiggle the wheel left to right w/o actually moving the steering wheel.
its not that that bad, but it will cause pre-mature wear on your tires
No its pretty easy, only time it gets hard is when the tie rod spins and the nut wont turn because of. To remedy just squeeze them together with a big old pliers. One bolt on top and just spin it off. Just make sure to make where the old one was other wise your alignment will be way off. Generally a good idea to get it aligned anyway
i have the same damn thing happening right now. the other day i was going on this dirt road and there was this really loud pop in the front right wheel area. i have noticed significant wobble since then. i am not very familiar with suspension stuff so if someone could tell me exactly what needs to be replaced i would appreciate it.
Tyson
Suspension & Brakes
May 21, 2006 09:57 PM
RacerBoy
Apr 1, 2003 07:20 AM
