autopower material questions: race rollbar (not full cage)
Old Mar 3, 2002 | 08:24 PM
magic hat #9's Avatar
Default autopower material questions: race rollbar (not full cage)
i know dom is more desireable over erw because it is stronger and the tubing is a smaller diameter. i've also heard autopower used to make bars out of chromoly which is even stronger than dom. can anyone offer more insight into the pro/cons of chromoly? what is a reasonable price to pay for chromoly bar in excellent shape?
Old Mar 4, 2002 | 04:54 AM
Default Re: autopower material questions: race rollbar (monkey_truckR)
anybody? chromoly?
Old Mar 4, 2002 | 05:04 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
if i am not mistaken, we don't have any options with the autopower for our cars. i got mine from autopower directly, and they said it came only one way. i aksed if i could get the chromoly one, and they said no.
Old Mar 4, 2002 | 05:30 AM
Default Re: autopower material questions: race rollbar (rodney)
yep, new we can only get erw, but i'm poor and would like to purchase a used bar. in the past, autopower did make bars out of erw, dom, and chromoly.
Old Mar 4, 2002 | 06:23 AM
RedheadRacing's Avatar
Autopower dose not make any cages with Chromoly any more. If you are looking for a good deal on a Autopower cage let me know, we carry Autopower.
Shawn@sound-buys.com
Old Mar 4, 2002 | 06:25 AM
XR4racer's Avatar
Remember.. ERW and DOM are the exact same material... the only difference is in the way the cage is constructed (welds)... the construction of the DOM is stronger.. allowing the cage of a 1.5" diameter to be just as strong as an ERW cage of 1.75" diameter. This, in turn is what makes the DOM cage lighter... not the fact that the material itself is lighter.. just the fact that it is less material. Chromoly is a different material with different properties altogether.
Old Mar 4, 2002 | 06:42 AM
Willard's Avatar
What is ERW, DOM and Chrome-Moly?
ERW stands for Electric Resistance Welded. This is a mild steel tubing that started out as a flat sheet of steel, formed into tubing and welded. DOM stands for Drawn Over Mandrel and it is actually ERW tubing that has gone through a second process that shapes and smooths the tubing so that the walls are more uniform. This in turn makes the tubing stronger than the original tubing. Chrome-Moly is an alloy of steel which incorporates both Chromium and Molybdenum in the process. Please don't confuse Chrome-Moly with Chrome finish. All our roll bars are painted Black.
What type of tubing should I use in the manufacture of my roll bar or cage?
The answer to this question is usually found in your rule book. All street roll bars are made with ERW. Most race roll bars and cages are made with ERW tubing unless specified otherwise.
When can DOM tubing be an advantage over ERW?
DOM is a stronger tubing , so some sanctioning bodies allow you to reduce the tubing size of your cage when using DOM compared to ERW. This does not apply to roll bars, only roll cages. This also only applies in certain classes within these racing organizations. Some classes do not allow the use of ERW tubing. DOM, however, is a more expensive tubing, so expect to pay more.
http://www.ioportracing.com/faqs.htm
Will
Old Mar 4, 2002 | 07:26 AM
yoshi234's Avatar
I shoot brides
not sure what mat'rl mine is, but got the bar in yesterday
install w/ the side panels
yshi - who'd like to thank ITR607 and AoiGsr for helping w/ the install
Old Mar 4, 2002 | 07:38 AM
Reid's Avatar
Global Moderator
Default Re: autopower material questions: race rollbar (yoshi234)
Took lots of pics, I hope.
Old Mar 4, 2002 | 11:55 AM
travis's Avatar
Default Re: autopower material questions: race rollbar (Willard)
You also can't weld on to Chrome-Moly, so adding stuff later is a no-no. I believe all of the new race roll bars are ERW, while all of the full cages are DOM. I have the ERW roll bar, soon to be replaced with a DOM cage. The weight is very similar, but the ERW tubing is just bigger. That's no big deal for the rear since it's not in your way, but in the front halo, you want small tubes so that they don't take up a lot of space.
Old Mar 4, 2002 | 11:59 AM
GRM Scott's Avatar
25 Year Member
yeah yoshi, let's see the pics! Told you that those rear ones were gonna be a PITA...i really need to employ a limber midget for working on the cramped parts of my car.
Old Mar 4, 2002 | 12:04 PM
travis's Avatar
Default Re: autopower material questions: race rollbar (Aleph)
If you find one, I'll split the cost with you...
Old Mar 4, 2002 | 12:15 PM
yoshi234's Avatar
I shoot brides
Aleph:
not pix of the install process b/c your's and travis' site is all that's needed to install it. I"m not sure I wana go thru this process again
yshi - who was stuck inside the R throughout the install like a reese's monkey inside a small cage
oh, I am NOT available for hire
Reid:
I did pix of how the takata harness is installed. will put those up later
Old Mar 4, 2002 | 12:58 PM
ITRbroham's Avatar
shit post warrior
yshi - who was stuck inside the R throughout the install like a reese's monkey inside a small cage :
At first I thought of a chocolate covered monkey with peanut buttery inside with an orange shirt on until I figured out he meant a "rhesus monkey"
Old Mar 4, 2002 | 01:00 PM
yoshi234's Avatar
I shoot brides
Default Re: autopower material questions: race rollbar (ITRbroham)
rhesus, scheemus
yshi - who just finished eating some reese's candy for an after lunch dessert
Old Mar 4, 2002 | 04:23 PM
up!
thanks all! i had already seen the ioportracing site so i know the difference between erw and dom; i also know they only sell erw roll bars now. my question is about chromoly only. i'm thinking that a used chromoly rollbar would be very desireable because it is lighter, has smaller bars and is just as strong as the current erw bars.
another question: are the rear speakers functional with the rollbar?
Old Mar 4, 2002 | 04:28 PM
yoshi234's Avatar
I shoot brides
no, but yes....
no because it doesn't fit like it did factory
yes, b/c w/ very little modification, the speaker housing can be made to fit
yshi - who didn't put the speaker back in, but will reinstall it this weekend
Old Mar 4, 2002 | 04:56 PM
does anyone have an idea how much weight the chomoly bar saves? ioport says the difference in weight between erw and dom is 0.32lbs/ft. i would guess the full erw rollbar is going to weigh about 5-8lbs more; not a huge difference. it looks like the chromoly weighs about 0.6lbs/ft less than erw; this will add up very quickly, probably 10-16lbs!
Old Mar 4, 2002 | 04:57 PM
do the rear speakers even do anything in an integra?
Old Mar 4, 2002 | 05:03 PM
yoshi234's Avatar
I shoot brides
if you play around w/ the fader you'll see what it'd be like w/o rear speakers.
w/o the rears, sound seems to only come from the left speaker.
w/ the rear, sound seems to come from both left and right speakers.
yshi - who usually listens to talk radio so rear speakers shouldn't matter, but likes the rear fill anyways
MazworxRacing
30
Feb 18, 2014 12:38 PM
Fomoco
10
May 8, 2006 03:19 PM
bigBOI_92DA9
19
Jun 8, 2004 09:51 AM
DIY_Racing
Jul 16, 2002 09:43 PM
