B20vtec Problem? WAt Timing Belt/Wat Water Pump?
waz good HT Memebers?
B20b4 bottem End wit b17a1 head...ive used a b20 water pump wit a gsr timing belt, the car ran wired but strong? now i have a 22T Water Pump and gsr Timing belt, and it slacks, cant get it to go on perfect timing wit gsr parts ?...........one of my friends have their b20vtec wit b20 timing belt and b20 water pump,it runs good? so wat should i do?
B20 Timing Belt - B20 Water Pump
Gsr Timing Belt - Gsr Water Pump <belt Stays loose?
First timing building a motor
Anything Feed Back Would be helpful.
C-speed only has it for LS/VTEC but in the B20/VTEC they say use the same parts. And thats B18c belt and pump, but you said it doesnt work? What did you use before?
I would like to know this too for when i finish my build.
So your trying the same setup set up you did before but its giving alot of slack? Hows your tensioner?
What exactly do you mean the motor ran "weird but strong"?
Kirk@SyndromeAuto
25
Oct 9, 2015 08:03 PM
dElSleepiE
Jun 1, 2003 08:56 PM
