BIGGEST CAMS FOR A STOCK LSVTEC
I have a stock ls vtec. ( stock 2000 b16 head, and stock b18a1 bottom). The engine runs great but I would like more power. Can I run skunk2 stage2 cams with upgraded valve spring and retainers of course without upgrading the pistons. Is it possible?? How are the power gains???
I have heard that there are clearance issues with valves and pistons.
i wouldnt run anything bigger than a gsr cam with stock ls pistons, you might be able to gt away with itr's but only if you clay for clearance. Forget about the stage 2's unless you can installl a set of p30's or jdm itr pistons
Modified by PURPLETERROR aka BIGMATT at 9:30 PM 10/4/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorteg_96 »</TD></TR><TR><TD CLASS="quote">i would go with stage 1s you wont have much compression</TD></TR></TABLE> and you would have valve to piston contact
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingOfQB »</TD></TR><TR><TD CLASS="quote">no u wont i have done it</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT »</TD></TR><TR><TD CLASS="quote"> and you would have valve to piston contact</TD></TR></TABLE>
Are you kidding me? My roomate is running a 5.4cc dome with a thing headgasket, stock pr3 head with S2 Pro 1's....12.6 lift and he has NO problems with valve to piston clearences. To the origonal creator, I would get my hands on some type r cams if I was you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">
Are you kidding me? My roomate is running a 5.4cc dome with a thing headgasket, stock pr3 head with S2 Pro 1's....12.6 lift and he has NO problems with valve to piston clearences. To the origonal creator, I would get my hands on some type r cams if I was you.</TD></TR></TABLE>
What pistons is he running? obviously not a stock pr4 ls piston like the thread creator. How does your room mate like the pro1's? I love them in my 11.6-1 b16a and cany wait to use them in my lsvtec
What pistons is he running? obviously not a stock pr4 ls piston like the thread creator. How does your room mate like the pro1's? I love them in my 11.6-1 b16a and cany wait to use them in my lsvtec</TD></TR></TABLE>
how much power u puttin down with your b16?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Are you kidding me? My roomate is running a 5.4cc dome with a thing headgasket, stock pr3 head with S2 Pro 1's....12.6 lift and he has NO problems with valve to piston clearences. To the origonal creator, I would get my hands on some type r cams if I was you.</TD></TR></TABLE>
That has nohting to do with it. Stock LS pistons have a smaller valve releif then vtec pistons so bigger cams don't have as much clearance.
mattcivic
Oct 1, 2005 08:06 PM
majormaster01
11
Feb 4, 2005 10:31 AM
vtecb20coupe
Mar 6, 2004 11:33 AM
