17s.......
Old Mar 3, 2002 | 07:19 PM
k.'s Avatar
k.
New User
Default 17s.......
i have eibach prokits on my ej8, i have 16 inch wheels for daily use. if i put on my new 17s, will there be any rubbing? or will it fit pretty good? will it raise the car?
~k.
Old Mar 3, 2002 | 07:21 PM
fowler!'s Avatar
Default Re: 17s....... (k.)
offset? tire size? width of rim?
Old Mar 3, 2002 | 07:49 PM
FifthGearOnline's Avatar
Default Re: 17s....... (Fowler Yo!)
if they are 17x7's with a 42mm offset and 205 40 r17 tires no.......
Old Mar 3, 2002 | 11:46 PM
RedRacer's Avatar
New User
17x7's? with a 205/40 Im assuming... With the Eibach prokit's especially you shouldn't have any problems. I run 17's with a pretty low drop and it doesn't complain except for a few really big bad bumps at high speeds. But this is do to the fact that my car is way lower than eibach prokits will allow. So in other words, you should be fine. Any raising of the car will be minimal.
Word of caution: As previously mentioned, just make sure the offset is all good.
Old Mar 4, 2002 | 03:48 AM
jg's Avatar
jg
I have 17x7" 40 offset and 205/40 p7000 supersports on mine and had to "roll" the lips on front. Only rubs if the car is transitioning over steeply ramped or large curbed driveway entrances. Usually fine:
Old Mar 4, 2002 | 08:17 AM
k.'s Avatar
k.
New User
Default Re: 17s....... (jg)
yah its 17x7, ~40mm offset. i cant think of the size tires right now. but thanks folks!
~k.
Old Mar 5, 2002 | 09:32 AM
gohandbz's Avatar
I have 17x7.5 with 42mm offset and 205/40 tires on eibach prokit. The only problem i have with rubbing is when i make left turns and there is a bump on the road. Other than that i dont get any kind of rubs. My right turns dont rub. Go figure.
Old Mar 5, 2002 | 09:46 AM
k.'s Avatar
k.
New User
Default Re: 17s....... (gohandbz)
coo! i dont plan on driving on them a lot. since i have a second set of rims.
~k.
MRDC2
Feb 21, 2003 05:33 PM
lodown414
Nov 4, 2002 10:11 PM
SpeedMonkeyRacing
Sep 6, 2002 08:27 AM
Doogie Howser
Jun 24, 2002 05:34 AM
SuperRice
Mar 5, 2002 09:18 AM
