stock b16 turbo #'s
Old Oct 3, 2005 | 07:54 PM
1sikhatch's Avatar
Default stock b16 turbo #'s
anyone got numbers of turbocharged b16's with stock internals?
Old Oct 3, 2005 | 08:03 PM
crazyimport's Avatar
Default Re: stock b16 turbo #'s (1sikhatch)
1 million RWHP
Old Oct 3, 2005 | 09:56 PM
lodo1's Avatar
Default Re: stock b16 turbo #'s (crazyimport)
see my sig, that is at 10 psi on a sc61
Old Oct 3, 2005 | 09:58 PM
urbansi's Avatar
Default Re: stock b16 turbo #'s (tdocrx)
bottle necked b16 with Greddy kit 215whp. runs 13.7-13.8's all day long
Old Oct 3, 2005 | 10:19 PM
Topdawgg's Avatar
made 240.1 whp and 167.8 tq at 8psi with SSAC manifold and SSAC T304e 67 trim turbo
tuned with uberdata
Old Oct 4, 2005 | 06:02 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (Topdawgg)
Member G"UNIT made 330whp and 220 torque - Bone stock SiR2 JDM B16/SC61 on 11-12 lbs
Old Oct 4, 2005 | 06:05 AM
nsxmatt's Avatar
240 or so whp, times in sig. Stock B16 t3/t4 at 10lbs.
Old Oct 4, 2005 | 06:49 AM
1sikhatch's Avatar
Default Re: stock b16 turbo #'s (nsxmatt)
thats some good numbers, i think i'm gonna keep my b16 instead of gettin a b18 and see what i can get out of it. if im not satisfied i might get a b18 block
Old Oct 4, 2005 | 11:53 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">thats some good numbers, i think i'm gonna keep my b16 instead of gettin a b18 and see what i can get out of it. if im not satisfied i might get a b18 block </TD></TR></TABLE>
It should be plenty, just make sure to get it tuned. Good tuning is the key to having a strong/reliable motor
Old Oct 4, 2005 | 02:01 PM
red_crx's Avatar
Default Re: stock b16 turbo #'s (HybridHatch88)
Mine made 270 whp @ 8psi.....Now i'm running 11, but i haven't dynoed
Old Oct 4, 2005 | 02:21 PM
1sikhatch's Avatar
Default Re: stock b16 turbo #'s (red_crx)
about the ecu, right now i got a skunk 2 chipped p28, i figure im gonna have to upgrade so what is recommended and whats easiest to tune?
Old Oct 4, 2005 | 02:24 PM
LostSolVTEC's Avatar
290hp 200trq at 9.5lbs
T3/T04e .57trim .63 A/R
Old Oct 6, 2005 | 07:33 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">about the ecu, right now i got a skunk 2 chipped p28, i figure im gonna have to upgrade so what is recommended and whats easiest to tune?</TD></TR></TABLE>
There are lots of choices when choosing a standalone - Ubderdata, Crome, Hondata, AEM, Power FC, etc. It is all in what you want and how much you want to spend.
Old Oct 6, 2005 | 07:39 AM
hinds90's Avatar
Default Re: stock b16 turbo #'s (LostSolVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostSolVTEC &raquo;</TD></TR><TR><TD CLASS="quote">290hp 200trq at 9.5lbs
T3/T04e .57trim .63 A/R</TD></TR></TABLE>
Would like to know more
Old Oct 6, 2005 | 08:37 AM
tony n.'s Avatar
Default Re: stock b16 turbo #'s (hinds90)
in sig
Old Oct 6, 2005 | 10:37 AM
LoSt is BlaCk's Avatar
Default Re: stock b16 turbo #'s (boosted2cam)
any more?
Old Oct 6, 2005 | 10:42 AM
Maveric's Avatar
Default Re: stock b16 turbo #'s (LoSt is BlaCk)
320-335
is about the normal max
unless mase is tunning then you can make like
500+
Old Oct 9, 2005 | 03:12 PM
what else would you like to know hinds90?
Old Oct 9, 2005 | 03:44 PM
1sikhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam &raquo;</TD></TR><TR><TD CLASS="quote">in sig
boosted2cam thats some impressive numbers, thats like where i wanna be. whats ur turbo setup?
Old Oct 9, 2005 | 05:59 PM
tony n.'s Avatar
boosted2cam thats some impressive numbers, thats like where i wanna be. whats ur turbo setup?</TD></TR></TABLE>
thx,
turbo setup: sc61, neukin manifold, neukin 3"downpipe, kteller 3"exhaust i made 295whp @12psi
i got it setup where lo boost is 8psi and when i hit 40mph it hit hi boost which is 12psi
Old Oct 9, 2005 | 06:41 PM
1sikhatch's Avatar
what ecu are u running?
Old Oct 9, 2005 | 07:00 PM
XxRoCkMaNxNEOxX's Avatar
277 whp 191 tq 13psi conservative, St00pid tuned. on precision sc34 w/ a/r 48 and blox manifold and full 3" dp - exhaust
Old Oct 9, 2005 | 08:27 PM
when are you seeing full boost on the SC61? the spool time was the only thing that kept me from gettin that turbo for the stock B16
Old Oct 10, 2005 | 03:23 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostSolVTEC &raquo;</TD></TR><TR><TD CLASS="quote">when are you seeing full boost on the SC61? the spool time was the only thing that kept me from gettin that turbo for the stock B16</TD></TR></TABLE>
I am at full boost (10 psi) at about 5200. SC61 E housing 69 trim. Not bad, but not great either. All stock B16A2
Old Oct 10, 2005 | 06:12 AM
7k rdlne's Avatar
287whp 203wtq on 12psi
60 trim .63 exhaust
stock b16 with type r cams and inline pro 3mm headgasket
