is it worth it to get the venom IM vs the jg edelbrock?
Old Oct 3, 2005 | 07:32 PM
Black R's Avatar
25 Year Member
Default is it worth it to get the venom IM vs the jg edelbrock?
It looks like it's a $100 difference between the two - with the venom costing more.
Is it worth it?
Old Oct 3, 2005 | 07:35 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: is it worth it to get the venom IM vs the jg edelbrock? (Black R)
bump im contemplating about these 2 as well
97CWITR's Avatar
I've seen some damn good numbers on the jg IM. Not very familiar with the venom.
I'd have to go with the JG.
.dave's Avatar
i HAS questions ?
Go with the Edelbrock. It'll save you a ****-ton of headaches you would've had with the Venom.
Old Oct 3, 2005 | 07:38 PM
wantboost's Avatar
Who is Mr Robot?
jg is a better flowing mani
Old Oct 3, 2005 | 07:55 PM
eg crunkmonster's Avatar
Default Re: is it worth it to get the venom IM vs the jg edelbrock? (wantboost)
this is one where id go with the name thats behind it. the venom stuff ive seen is garbage.
Old Oct 3, 2005 | 08:49 PM
m R g S r's Avatar
Default Re: is it worth it to get the venom IM vs the jg edelbrock? (eg cookiemonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster &raquo;</TD></TR><TR><TD CLASS="quote">this is one where id go with the name thats behind it. the venom stuff ive seen is garbage.</TD></TR></TABLE>
mine is fine
all top end power thou.....
Old Oct 4, 2005 | 09:20 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">jg is a better flowing mani</TD></TR></TABLE>
.....have you bench flowed them both?
Old Oct 4, 2005 | 09:31 AM
wantboost's Avatar
Who is Mr Robot?
dont need to.
venum has a large plenum with straight entrances into each runner.... good for flow bad for aerodynamics... teh air tumbles when entering the runner.
jg edelbrock has tapered entrances into each runner, smoothing hte ariflow and producing more power
Old Oct 4, 2005 | 09:50 AM
dnbruut's Avatar
no love for blox?
btw i have seen one case where the edelbrock caused a engine to run lean on cil. 3.
annybody heard about this?
Old Oct 4, 2005 | 09:57 AM
.dave's Avatar
i HAS questions ?
Default Re: is it worth it to get the venom IM vs the jg edelbrock? (dnbruut)
If I was going to get a manifold for a B-series engine, it would be the AIR intake manifold or I'd hold out for the Full-Race Intake manifold. The Full-Race already proved that it is just as capable as the AIR (which made more power throughout the entire RPM range than the Edelbrock), and that was just on its initial design.
Old Oct 4, 2005 | 11:01 AM
Soccerking3000's Avatar
Default Re: is it worth it to get the venom IM vs the jg edelbrock? (daveG)
i beleive the venom has a radius going into the runners so the air doesnt tumble in the runners,...
Old Oct 4, 2005 | 11:13 AM
andysila's Avatar
Default Re: is it worth it to get the venom IM vs the jg edelbrock? (Soccerking3000)
edelbrock
choiboiracing(gary) is runnin one on his (expected) 700hp+ SFWD.
heres a link https://honda-tech.com/zerothread?id=1187744
Old Oct 4, 2005 | 02:13 PM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">i beleive the venom has a radius going into the runners so the air doesnt tumble in the runners,...</TD></TR></TABLE>
That was what I noticed as well.....
Old Oct 4, 2005 | 03:04 PM
does the venom one have ports for iacv and other things as well?
Old Oct 4, 2005 | 03:23 PM
whatVTEC's Avatar
Default Re: is it worth it to get the venom IM vs the jg edelbrock? (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">does the venom one have ports for iacv and other things as well? </TD></TR></TABLE>
nope
Old Oct 4, 2005 | 03:26 PM
rtype11's Avatar
venom is junk, had one for years, lots of headaches no provisions for anything, new location for throttle cable, plus thin gauge plenum and runners may look like jiffy pop after No2 backfire.
Old Oct 4, 2005 | 03:33 PM
andysila's Avatar
Default Re: is it worth it to get the venom IM vs the jg edelbrock? (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">venom is junk, had one for years, lots of headaches no provisions for anything, new location for throttle cable, plus thin gauge plenum and runners may look like jiffy pop after No2 backfire.</TD></TR></TABLE>
i also heard that. there was a test between stock IM and venom in one of these magazines i have, it turned out that venom actually made less power.
Old Oct 4, 2005 | 04:09 PM
Default Re: is it worth it to get the venom IM vs the jg edelbrock? (andysila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila &raquo;</TD></TR><TR><TD CLASS="quote">
i also heard that. there was a test between stock IM and venom in one of these magazines i have, it turned out that venom actually made less power.</TD></TR></TABLE>
your onyl going to see gains from a venom manifold, way up in the rpm range with boost, you saying that means jack **** without knowing the setup, if you through a venom mani on a stock car you would lose all low end...
Old Oct 4, 2005 | 05:12 PM
Garcia-Racing's Avatar
We have no problem making over 700 whp on a venom im.
Old Oct 4, 2005 | 05:47 PM
MyEvo's Avatar
I'd say JG edelbrock... I have a Honda engine builders book with dyno runs and they only made some hp on the Vemon at rpms over 9k meanwhile they lost power like crazy below there. You may laugh but the B16 intake manifold actually produces very good numbers and a solid powerband specially on a street motor.
sohcef9
89
Jun 1, 2014 06:13 PM
RBNightMare
Honda Motorcycles
10
Feb 22, 2008 01:52 PM
98se-rTurbo
Welding / Fabrication
13
Nov 3, 2005 07:42 AM
K I O K E N
Dec 13, 2004 11:41 AM
Layziebtnh055
Jun 14, 2004 10:52 AM
