low compression built turbo motor running N/A?
how should it run? here are the specs
81mm JE pistons 9.1:1 compression.
Eagle H-beam Rods.
ACL Bearings
Golden Eagle Block Gaurd
ARP Head Studs
Stock GSR head including Distributor with MSD coil..
JG EDELBROCK Intake manifold
alternator
TYPE R Valve Cover
ACT 6 puck clutch, with ACT flywheel.
2100$ asking price. made 447whp
will be with stock GSR injectors, and LS tranny, but will it run like complete ***?
Eagle H-beam Rods.
ACL Bearings
ARP Head Studs
alternator
TYPE R Valve Cover
tonyboosted
22
Dec 21, 2009 03:45 AM
tegasaurus
Jan 20, 2004 05:43 PM
