cam timing #1 TDC at 4 oclock
ok #1 Closest to timing belt at TDC the cam gears are around 4 oclock
they should be at 12 right?
is this why my car wont start?
also how can the timing be of this bad on an engiine that came straight from japan?
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Yes with cyl1 at TDC the UP marks should be UP (12 o clock)
Yes this is why the car wont start.
It probably didn't come straight from Japan. It has probably been sitting in a warehouse somewhere in North America for a while now even though it is a JDM engine. Basically to answer your last question, **** happens. Could have been a loose belt that slipped when you first tried firing it. Could have slipped while the car it was origionally in was running, who knows? Only God I guess.
You may have problems though since Honda engines are interference engines (the valves and pistons share the same space in the cylinder just not at the same time.). Quit trying to start the car, properly setup your timing, do a valve clearance inspection/adjustment, compression and leak down test to see if you have any bent valves.
Good luck on this one.
here you go:
But yeah, if your block is at TDC, then your timing is way off. You need to have the little hash marks lined up properly, and they arent'
I would do something with that upper timing cover too. Don't want any openings for rocks or other debris to get in there.. On the crankshaft gear there will be marks that align to indicate TDC of the No1 cyl. or you could remove the spark plug and insert a screwdriver in there and when it stops moving up your at TDC, though I consider this method primative.
i did the screwdriver thing so i didnt have to take it apart yet. is there 2 TDCs one for compression and 1 for exhaust. cause if i keep turning the crank and come to the top of number 1 again im at 10 oclock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 »</TD></TR><TR><TD CLASS="quote">I would do something with that upper timing cover too. Don't want any openings for rocks or other debris to get in there.</TD></TR></TABLE>
I don't put the top or bottom on my motors, and i have never had a problem, street driven
although i would recomend the bottom cover be on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Damn no lower cover, you are brave my friend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi »</TD></TR><TR><TD CLASS="quote">I don't put the top or bottom on my motors, and i have never had a problem, street driven
Yeah, but if a rock or bolt gets dropped down into the lower cover there is no way to get it out unless you feel like taking the crank pully off, which is a HUGE pain in the ***.
If a rock or bolt falls down there it has no where to go so it bounces around and chews up your timing belt.
I'd rather not mess up my engine because I didn't feel like putting a timing cover on. To each his own though.
</TD></TR></TABLE>Yeah, but if a rock or bolt gets dropped down into the lower cover there is no way to get it out unless you feel like taking the crank pully off, which is a HUGE pain in the ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">I'd rather not mess up my engine because I didn't feel like putting a timing cover on. To each his own though. </TD></TR></TABLE>
its not because "i don't feel like it" its because i'm **** retentive about my t-belt and i watch it very closley. like u said to each his own its just how i do things
