Erratic Speedometer
Old Mar 3, 2002 | 05:54 PM
nickgomez's Avatar
Default Erratic Speedometer
My 1990 CRX SiR speedometer doesn't move sometimes. At other times it flicks around wildly.
What can I do to fix it? Thanks.
Old Mar 3, 2002 | 05:56 PM
Jared's Avatar
Default Re: Erratic Speedometer (nickgomez)
Assure that the cable is properly seated in the tranny as well as the cluster. If it is ok on both ends, replace the speedometer cable.
Old Mar 3, 2002 | 05:58 PM
ZeRo's Avatar
your speed sensor is pooped out , you need a new one, there cheap goto you local auto parts store, but first check the speed sensor on you tranny ,stand on the passenger side of the car look straght down at the tranny you should see a plug goin into the top of the trans, take it an clean a little an put it back in might be a bad connection, check to see if it worked if it didnt you need a new one
Old Mar 3, 2002 | 06:00 PM
nickgomez's Avatar
Default Re: Erratic Speedometer (ZeRo)
Thanks. I believe my car uses a sensor, not cable. I will go check it later. (At work now).
TMC_EF
Jul 16, 2007 10:37 PM
EK FLY
Feb 8, 2006 01:02 PM
kim_2_da_chee
11
Oct 8, 2003 09:02 AM
foesicks
May 6, 2003 12:17 PM
Quik Chris
Aug 8, 2002 09:53 AM
