car wont rev freely
Old Oct 3, 2005 | 12:02 PM
AMLS4dr200whp's Avatar
Default car wont rev freely
ok hes my problem just yesterday when I was driving my 1995 integra LS and it started to not rev freely like it feels like it lost alot of power, it was like takin its time to get to 3k rpm so I was thinkin it could be the fuel pump but dunno. has anyone experienced this problem let me kno thanks ahmed.
Old Oct 3, 2005 | 01:09 PM
Lauj87's Avatar
check your plugs and wires. did your car start to sound funny too?
Old Oct 3, 2005 | 01:31 PM
Jason.'s Avatar
Default Re: car wont rev freely (AMLS4dr200whp)
Pull your plugs out and check the tips. When was your last complete tune up?
Old Oct 3, 2005 | 03:14 PM
1badda's Avatar
Default Re: car wont rev freely (JasonGS-R)
uncle car is the same but we got a da. I change fpr, fuel filter 4 times, Plug,wires , cap , rotor, clutch . It Just feel as if there no power till after 3000-3500 rpm. Really need help what the hell is wrong with this car. Checked the injectors there all clicking so dont know what else it could. Timing on the car is fine also . So what is it fellas
Old Oct 3, 2005 | 03:35 PM
1badda's Avatar
Now everytime i turn wheel car revs up and goes down when i am at a stand still. Is that normal or no
Old Oct 3, 2005 | 03:42 PM
SYTFU Tommy.'s Avatar
Default Re: (streetaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetaccord &raquo;</TD></TR><TR><TD CLASS="quote">Now everytime i turn wheel car revs up and goes down when i am at a stand still. Is that normal or no </TD></TR></TABLE>
that is normal since you have power steering. the extra rev to pump the fluids around.
Old Oct 3, 2005 | 03:52 PM
Lauj87's Avatar
check your timing might be off too...the car should produce constant power till the end of the power band.
Old Oct 3, 2005 | 04:05 PM
I am thinking the rotor thats the only thing that I have not replaced yet
Old Oct 3, 2005 | 04:37 PM
1badda's Avatar
What else would it be . This **** is pissing me off.
Old Oct 3, 2005 | 06:58 PM
allmotorteg_96's Avatar
try pressing your plug wires on, sometimes old wire pop off.
Old Oct 3, 2005 | 07:18 PM
Racermech's Avatar
Default Re: (allmotorteg_96)
do a valve adjustment. Are you throwing any codes? Is there any radiator fluid in the oil? Does it smoke at all?
What do the plugs look like after a couple hundred miles?
Old Oct 4, 2005 | 07:34 AM
how does a bad a rotor in a distributor cap look like cuz I think I have a bad rotor
Old Oct 4, 2005 | 08:36 AM
Racermech's Avatar
if you have the cap off you are allready 3/4 on the way to replacing the rotor, just replace it and see if it helps
hondasol90
Jul 12, 2010 02:00 PM
zenon8890
Jun 24, 2007 11:10 PM
JDMGSRCRX
10
Mar 31, 2004 10:50 AM
Rwecked
Jun 25, 2003 05:46 AM
