Is it okay to remove the head of my engine throughout all winter
Old Oct 3, 2005 | 10:43 AM
Jonovision's Avatar
Default Is it okay to remove the head of my engine throughout all winter
Well is it because i wanna do some headwork while the season is done
If so,what should I do for oil?
-Should I drain it?
-Put brand new oil it before removing the head?
Old Oct 3, 2005 | 10:50 AM
Baz007's Avatar
Default Re: Is it okay to remove the head of my engine throughout all winter (Jonovision)
Hello, my first post!!!
Not sure what the weather is like for you, as i'm in England.
However, if you rub a bit of oil down the bores and keep the block covered, it'll be fine..
To be extra cautious, if you spray a little bit of penetrating fluid down the bores every month or so.. That'll be even better
Old Oct 3, 2005 | 10:53 AM
Doeboy's Avatar
will the car be sitting outside all winter?
if so cover the cylinders up with a towel and then a tarp of some sort. lubrication is your friend.
Old Oct 3, 2005 | 10:54 AM
Luserkid's Avatar
Default Re: Is it okay to remove the head of my engine throughout all winter (Baz007)
You could leave the oil in there if you want. And if your leaving the motor in the car cover it with a plastic bag. And like once every 2 weeks rotate the motor.
Old Oct 5, 2005 | 01:40 PM
Doeboy's Avatar
rotation!!!!! good addition.
RDAYA0
21
Apr 2, 2010 07:55 AM
Hondapreludeg
Apr 20, 2008 09:52 PM
aznej2
Nov 21, 2006 02:12 PM
spidermancivic
Aug 12, 2005 04:44 PM
