mini me vtec swap vtec not working
Old Oct 3, 2005 | 09:37 AM
tlieu88's Avatar
New User
Default mini me vtec swap vtec not working
i put a 97 y8 head on a 97 y7 block. there was oil restrictor in the block so i just bolted the head on. the engine runs fine but when vtec kicks in the it just starts to bogges. did i must something when i installed the head?
Old Oct 3, 2005 | 11:01 AM
Bambin0's Avatar
Default Re: mini me vtec swap vtec not working (tlieu88)
I think that you're suppose to remove the oil jet(if there is one) on the block, or vtec will not engage. When I did my mini-me with a Y7 block, there was no oil jet. I just bolted up the head, ran the vtec and vtec oil pressure wires. Make sure that you wired up the vtec wires to the correct location on the ecu. Also, make sure the wire for the vtec oil pressure is being grounded properly. That will also cause the vtec to not engage. good luck
What ecu are you running? OBD-2 civic vtec ecu is a P2P, and non-vtec is P2E
Old Oct 3, 2005 | 11:28 AM
tlieu88's Avatar
New User
Default Re: mini me vtec swap vtec not working (Ek9_Civic)
swap it into a 93 civic si/ex has vtec wired already and iam running the stock p28.
yeah there was no oil jet in the block.
redrix
Apr 21, 2013 01:06 AM
4.8t
Aug 2, 2011 08:36 PM
nissanpwrds14
Oct 20, 2003 06:42 PM
yellowcrx88
Jul 6, 2003 10:31 PM
vspec12
Nov 5, 2001 05:25 AM
