blowing off in neutral? need a small turbo for it?
Old Oct 3, 2005 | 08:53 AM
turbotime's Avatar
Default blowing off in neutral? need a small turbo for it?
Hey i was wondering how some people blow off in neutral. You know, rev the engine and it blows off? My buddies eclipse does this.. is it just cause it has a really small turbo and it can spool up in neutral?
I have a t3/t4 and even if i rev it to like 5krpms in neutral it doesnt blow off... opf course it blows off fine in gear and such.
Not like its a big issue i was just wondering the technical side behind this?
Old Oct 3, 2005 | 08:57 AM
The Weather Man's Avatar
Does it blow off when you have it in gear and the clutch is engaged?.................
...........try revving to around 8k in neutral and see if it does it
You have to create excess pressure for it to disperse the surplus.
Old Oct 3, 2005 | 09:00 AM
turbotime's Avatar
it does when i shift or let off the gas in boost but if im just dead stopped i cant make it blow off.
Be it neutral revving or putting it in first, holding down the clutch and revving.
I can get it to like just under 0psi but thats it, and thats at like 5krpms....
should i be able to blow off at a dead stop with a t3/t4 turbo?
Old Oct 3, 2005 | 09:04 AM
AspectIndustries's Avatar
Default Re: (turbotime)
My t3t4 does this, only when I rev to 7k+rpm.
Old Oct 3, 2005 | 09:07 AM
turbotime's Avatar
yeah i dont really when to rev it that high just to blow off at someone, thanks thats what i wanted to know
it just takes longer to spool thana lil turbo
Old Oct 3, 2005 | 09:10 AM
beepy's Avatar
Default Re: blowing off in neutral? need a small turbo for it? (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">My buddies eclipse does this.. </TD></TR></TABLE>
The DSM BOV is open with vacuum, while most aftermarket BOV's require some boost to open. In other words, you don't need to make boost to make the "pssss" sound with a DSM BOV.
Old Oct 3, 2005 | 09:11 AM
turbosi03's Avatar
you didn't understand why you can't spool the turbo at idle and you have a turbo civic?
Old Oct 3, 2005 | 09:15 AM
vaporboy12's Avatar
Default Re: (turbosi03)
you have a bigger turbo so its harder for it to get moving with no load on the motor. get a 2step and build boost at idle eheh
Old Oct 3, 2005 | 09:17 AM
turbotime's Avatar
yeah i have an hks ssq so i assume it only open under boost.
i got hhondata with 3step just havent installed teh clutch switch yet and setup the steps- i hear it a real bitch
Old Oct 3, 2005 | 10:03 AM
vaporboy12's Avatar
yeah well the hondata 2 step sucks doesnt really build boost just hold you rpm because it cuts fuel and not ignition
Old Oct 3, 2005 | 11:02 AM
HiProfile's Avatar
Default Re: (vaporboy12)
anti-lag + neutral rev = blowoff...and extreme stress
Old Oct 3, 2005 | 11:10 AM
Still_Good's Avatar
Default Re: (HiProfile)
As said, you need something that will cut spark and (if its worth its salt) retard timing to make boost.
Also as said, this is not a function you should abuse often, nor one you want engaged all the time, ALS tends to destroy turbos unless they're designed for it or particularly well built.
Old Oct 3, 2005 | 12:30 PM
BoOstedEM1's Avatar
Why do you want to blow off so bad.Just asking
Old Oct 3, 2005 | 01:13 PM
turbotime's Avatar
cause im ANGRY aaarrgghh
nah i just wanted to make sure nothing was wrong
Old Oct 3, 2005 | 01:23 PM
notoriousB's Avatar
LOL angry - that's funny - the only time I got my t3/o4 turbo to blow off at idle was when I was super pissed off and revved the **** out of my car at someone who cut me off.
Old Oct 3, 2005 | 02:12 PM
Muckman's Avatar
Moderator in Chief
Default Re: (notoriousB)
i bet that scared them.... ha
Old Oct 3, 2005 | 03:36 PM
sohcThatch's Avatar
well i always thought that factory turbo cars can blow off by reving is because its actually made for turbo, so u know that motor was done perfect far as tuning and ect. and when you go and try to turbo something else you not gonna get it as perfect as factory turbo motor because they think about this way more deeply than us i think. jus imo cuz think about it a eclipse or sr20 or anything thats turbo can rev it jus a little bit and you hear that blow off valve but when one of us do it we dont hear ****. cuz i jus hear a whistle if i rev mine and thats jus prolly cuz i got a type s bov.
Old Oct 3, 2005 | 04:44 PM
SE-Rawkus's Avatar
Default Re: (sohcThatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcThatch &raquo;</TD></TR><TR><TD CLASS="quote">jus imo cuz think about it a eclipse or sr20 or anything thats turbo can rev it jus a little bit and you hear that blow off valve but when one of us do it we dont hear ****. </TD></TR></TABLE>
Sorry, that is incorrect. Atleast SR20s are not so easy to blowoff like the DSM or SRT4s.
Old Oct 3, 2005 | 05:00 PM
yee SERIOUS's Avatar
yeah you need a smaller turbo. or hold the ebrake. hehehe
Old Oct 3, 2005 | 05:40 PM
Calvinator's Avatar
Default Re: (undercoverdc2)
Yeah im pretty sure its due to the size of turbos used by hondas. When you think about it, dsms are using 2.0 dohc motors with t25s and 14bs and look at the turbo size on a wrx or srt4. They are pretty small.
Old Oct 4, 2005 | 08:19 AM
sh!tsWEAK!'s Avatar
Default Re: (xtremeazian)
Yeah man, it's normal. I have a stock b16 with sc61, and i don't hear my Greddy Type S blow off in neutral unless i rev it to like 7k. But under normal driving, it works perfectly. I mean, if you really want it to blow off all the time you could adjust the bov to open ealier (before 0 on the boost gauge), but that would just be stupid.
I'm pretty sure it's just the bigger turbo. Cuz i let a friend with a turbo eclipse (factory dsm turbo) borrow my type s and it was blowing off under very low revs. But my sc61 doesn't do that.
Old Oct 4, 2005 | 10:29 AM
kameleon23's Avatar
Default Re: (BoOstedEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstedEM1 &raquo;</TD></TR><TR><TD CLASS="quote">Why do you want to blow off so bad.Just asking </TD></TR></TABLE>
Havent you seen Fast and the Furious? Thats Bad ASSTH!
Old Oct 4, 2005 | 10:32 AM
andysila's Avatar
wheres JDMJoe for this one... hah
Old Oct 4, 2005 | 12:01 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (andysila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila &raquo;</TD></TR><TR><TD CLASS="quote">wheres JDMJoe for this one... hah</TD></TR></TABLE>
tell me about it, the guy is a dumb bastard
Old Oct 4, 2005 | 12:21 PM
a1320addict's Avatar
Default Re: (wantboost)
try adjusting your windshield wiper led's...they should make it blow off at idle
